Question about Whirlpool Washing Machines
Whirlpool 6th sense - pump issue
6th sense
    Sergeant:
  • 291 Answers
The drain pump probably just needs cleaned. If you've never cleaned it i can direct you to videos that are step by step. Let me know.
Posted on Jan 20, 2013
Testimonial: "thank you was nice to receive support for my Whirlpool front loader washing machine. I did view some youtube videos, but then risked a hot (60deg)wash empty wash and it worked perfectly, then with trepidation did a quick wash (30 min)today 30 degrees with clothes and had no problems. I am not totally convinced that its fixed but so far so good. I did remove the filter x 3 and there was no obvious block but maybe the pump does need cleaning so will do more very hot washes."
  • 3 more comments
  • Anne Cook Jan 21, 2013
    Yes please, will give this a go before calling in repair company
  • B.H. Countryman Jan 21, 2013
    Can you give me the model number that is on the machine? Or tell me is it top loading or front loading, approximate age, etc. Thanks.
  • B.H. Countryman Jan 23, 2013
    That's nice to hear. Good luck.
  • saraht996
    saraht996 Feb 08, 2013
    I'm having the same problem. I cleaned the filter but don't know how to access the pump. Can't you post a link to any helpful videos?
  • B.H. Countryman Feb 09, 2013
    I'm sorry, i should have just done that. Here you go:http://www.youtube.com/results?search_qu...
SOURCE: My Whirlpool Washing Machine 6th Sense 10kg
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Posted on Oct 30, 2011
  • 1028 Answers
SOURCE: clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Posted on Apr 28, 2008
  • 6 Answers
SOURCE: F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
Posted on Jul 16, 2008
SOURCE: whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Posted on Aug 17, 2008
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
I have whirlpool aquasteam 6th sense fromtliad washer 9760. It wont drain the water
Probably you have a clogged water pump clean it if not clogged then you have to know how to check if you have voltage to it, do so if you have 120 volts then it's your water pump http://www.appliancepartspros.com/whirlpool-washer-drain-pump-280187-ap3953640.html
Apr 29, 2016 | Whirlpool Washing Machines
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
Whirlpool 6th sense fridge freezer instructions
unplugging the unit for 10 minutes is the reset feature. other wise I refer you to the owners manual
Dec 22, 2017 | Whirlpool Refrigerators
Were is the pump on whirlpool 6th sense
Whirlpool recently launched a new site and I find they have made it easier to find the solutions I need for DIY. www.whirlpoolwaterheaters.com/products/natural-gas/n50t61-403/
Jun 24, 2012 | Whirlpool 6th Sense 50-Gallon 6-Year Tall...
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
Mar 15, 2010 | Whirlpool Washing Machines
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Washing Machines Logo
960 people viewed this question
Dan Webster
Dan Webster
Sal De
