Question about Craftsman Sears Yellow Safety Key For Switch, Table Saw,radial Arm,jointer,band
Lost sears tablesaw safety key - Craftsman Sears Yellow Safety Key For Switch, Table Saw,radial Arm,jointer,band
Lost safety key
Your Sear store should be able to get one for you.
Aug 21, 2014 | Washing Machines
How can i bypass the safety switch on ryobi tablesaw
Its a mechanical action and not electrical. Find something small enough to fit into the lower hole where a prong on the safety key would insert.
Press your makeshift key in until you hear the click.
Saw is now running.
Press the red switch cover down turn off.
In the fullness of time replace the switch with a rocker.
Feb 17, 2013 | Ryobi Saws
Fan and fan guard needed for 3 hp motor. Have serial number for motor on a 12 inch craftsman tablesaw.
I'm assuming your saw is a model 351.228040 or a 351.228020. Manual is here.
See page 18, Figure 7 for the Blade drive exploded diagram.
Sears doesn't appear to have a part number for the fan and fan guard.
It looks like you can replace the entire motor and key for $217.55 (as of 6/13/2010) which isn't too bad for a 3 HP motor. Part number is 15094.00 and clicking it will link you to their parts site.
If this answer was useful, please give it a thumbs up. Thanks!
Jun 07, 2010 | Craftsman 10" Table Saw
Replace safety key?
I tried Tool Parts Direct, but their exploded view only shows the whole switch, which apparently includes the key. I'm not sure what the Hitachi key looks like, but if it's compatible with the ones Sears uses, I know they used to sell replacement keys in a blister pack (maybe 4 - 6 pcs) I bought a package of them from Sears several years ago.
You can also send a request for help to Hitachi customer support at: http://www.hitachi.com/GlobalSupport/ContactUs?form_type=global_support
Jan 27, 2010 | Hitachi SB10Y 4 X 8 Inch Belt Disc Sander...
I lost the key to my 1998 Pro Tech 4002 table saw and can't run it. Is there a way to get a key or override this feature?
most keys are generic but u can call or go to sears for replacement key some of the bigger sears stores have them in stockits never really a good idea to override a safety but yes it can be done
Jan 18, 2010 | Sears Saws
I need a table saw motor model rm871 where can i go to get it?
Sears.com would be the only place that I know of, I also think that the motor number has changed,
Oct 02, 2009 | Saws
Need owners manaul for a craftsman tablesaw modle 113-241680
Check out the sears.com website....you can usually find and download the owners manual there.
Sep 04, 2009 | Craftsman Saws
Need motor for craftsman table saw model rm871
Go to midlandhardware.com.For about $4.00 more than just price ofthe motor,you get the complete saw 15amp.motor with a laser guide!The table saw has a 3yr. warranty,3 extension wings,and a sturdy stand.Shipping to your door $24.00,$198.58 total.
Jul 03, 2009 | Craftsman Saws
I have a Craftsman table saw with a burned out motor. The motor model number is RM871. Where can I find one for less that the $130.00 that Sears wants for the motor. That's the price of the saw.
SOUNDS LIKE THE PROBLEM I HAD, BUT WAS JUST A SEIZED-UP BEARING. I WENT TO LOCAL ELECTRIC MOTOR REPAIR ($15.74) PARTS AND LABOR, THEY REPLACED THE BEARING, THERE ARE 2 BEARINGS ON IT, COST IS THE SAME FOR EACH. THE BEARING IS PRESSED ON, SO REPLACEABLE. HOPE THIS HELPED
Mar 27, 2009 | Craftsman 10" Table Saw
I have lost the safety key for my Weslo treadmill
Hi I folded up a piece of paper several times to make it into a small rectanguler shape and inserted into the slot for the key and it worked.
The replacement key doesn't need to be magnet just small enough to fit the shap of the slot is fine.Mine was a Weslo cadence 1000 (bought in 2002)
Jan 29, 2009 | Exercise & Fitness
Craftsman Sears Yellow Safety Key For Switch, Table Saw,radial Arm,jointer,band Logo
29 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
