Question about Samsung NP-R40 NP-R45 NP-R65" (CL102791)
Base system device driver for samsung R40 - Samsung NP-R40 NP-R45 NP-R65" (CL102791)
Samsung r40 reset to factory settings
hello there Start by pressing F4 when the BIOS "Samsung" screen is showing. This will allow you to restore the original operating system from the recovery partition, if is there. (Also try the other Fn keys - F6 and F8 may do something).
Otherwise you will need to beg, borrow or buy an XP Home installation CD and use that for a new installation. You can use the Samsung key on the bottom to activate it. You can get the R40 drivers from SamsungPC.
Feb 12, 2013 | Samsung NP-R40 NP-R45 NP-R65" (CL102791)
My friend got a Samsung R40 laptop as a gift, but it had a Korean O/S. I was able to load XP Professional on it, but now there's no audio. It says "no audio device installed." Got any...
when your friend give it to you did she/he also gives some cd installers? it says no audio device installed doesn't mean there's no audio card on it, it's just that windows xp doesn't support the audio card in the r40 laptop that you have. if you can do upgrade it to windows 7 it would be better because win 7 supports a lot of hardware. if you don't want just try to download the audio driver for you laptop. do you happened to know the audio card model of the laptop. you can see it as you turn on the your laptop you will see new hardware detected try to get the serial number of the device and ping me here so i can guide you were to download the sound card driver for you.thanks..
Jul 11, 2011 | Samsung Computers & Internet
Repairing a thinkpad r40. Can't get the sound to play
Yellow question marks would normally indicate that the drivers aren't installed.
Apr 28, 2010 | IBM ThinkPad R40 2897 Notebook
ThinkPad R40 2897 lost all internet. No Wireless, No Ethernet No
check the device driver status of network adopters in device manager .if it shows any error then reinstall the device drivers again.
if you are using WI-FI then reinstall the drivers of your wireless device.
and don't forgot to reboot your system after doing so.
if the problem exsist then contact your ISP.
they will provide the settings if any and i hope you are able to apply setting for the internet connections.
Apr 26, 2009 | IBM ThinkPad R40 2897 Notebook
Lost wireless - Ibm thinkpad r40
haha worrying isnt it...
after reinstallation of windows no drivers for blutooth , wireless quite often modem and same vga,
windows by default does not install because need specific software ...(drivers)
what you need to do is first of all find out what wifi it is ; like wlan400 e.g.
you then need to download and install the driver for it .as soon as the driver is present windows will detect and install device,
look in device manager for devices with no drivers intalled.
same precedure for each device.
Jan 24, 2009 | IBM ThinkPad R40 Notebook
Ibm thinkpad r40 windows xp-pro after formatting and re-installing the system, all updates and SPs downloaded and installed, the wireless "disappeared"! the radio led wouldn't lit, in the connection list...
if drivers installed device is looking for wifi manager which is the software package for wifi.
you can goto control panel open administrative tools select sevices and scroll to wireless zero config and press start.
this will then use windows settings.done
Thinkpad r40 - wireless disappeared
Go to the control panel, then System, then Hardware tab, then Device Manager. Then Network adapters - you should have two network adapters one LAN and one wireless.
If most likely have one, the LAN adapter and a yellow ? against a network adapter - this will be a wireless adapter (its not installed)
Check your BIOS and make sure the wireless card is enabled.
You need to download from the IBM/Lenove WEB site the wireless driver (there may be several types that is installed for your model laptop). Make sure you select the correct Windows version driver.
When you run the driver,it will uncompress and copy to your hard drive in C:\drivers. You can then install the driver from this directory. If it doesn't work then repeat with another driver, most likely one that works will be the Intel one.
I need to download my laptop PCI modems, interthenet contoller,wireless device laptop brand is IBM the modem would be R40 .
There are roughly 97 different downloads and driver available for an HP ThinkPad R40 starting here.
Should you want a more refined driver listing appropriate to your Operating System and laptop version, pls go here and input:
  • Brand: Notebooks and handhelds;
  • Family: ThinkPad R40;
  • Type: 2???? (this maybe found printed on a sticker underneath or stenciled on the casing, inside of lid, body such as 2681... 2899);
  • Model: (if asked, choice of 11A..Y11);
  • Operating System: choice of Vista, XP, others
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | Computers & Internet
No Sound on R40
your system may be designed this way. But you can refer to its manuals or online support to find out whether your PC really supports audio. Another thing is that the socket in your laptop may have lost its connection to the motherboard. But first thing you should check is that whether your operating system detects any new hardware. If yes just find the driver for it. You can download drivers from the manufacturer's website.
Oct 04, 2007 | IBM ThinkPad R40 2722 Notebook
ThinkPad R40 with no sound
http://www-307.ibm.com/pc/support/
Samsung NP-R40 NP-R45 NP-R65" (CL102791) Logo
95 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
