Question about liftmaster Home Security
How do I program a Genie G4050 garage door opener
The garage door opener does not have a "learn" button. How do I program a new remote to this garage door opener?
5 Suggested Answers
SOURCE: i have a pmx300IC genie
palm treo 700w off no open
Posted on Jan 19, 2009
  • 3197 Answers
SOURCE: Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Posted on Jun 01, 2009
SOURCE: Reprogramming a Genie garage door receiver
I ned a akai audio timer DT-100
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: remote missing on old dominator garage door opener
This is the most complicated way I know of coding a remote and I am a tech. who does this all the time.
Turn power off. Wait 3 sec's & turn back on. Quickly press program button on back of box twice. Lights will flash, bottom light will stay on. Press program button twice, & No. 3 light will start flashing. Press and hold your remote button until light stops flashing. Code will be accepted.
Posted on Feb 08, 2010
How to program a remote for a genie garage opener model 209
When programming a genie remote press the learn button
Then you will have to press the genie remote at least three times before it stores the code older genie models 5 times genie i
Apr 05, 2015 | Building Materials
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
How do i program my garage ope
Take your old remote and point it at the new remote while pressing 'learn' (or you might only press learn and then shoot the old signal into the new remote). Almost impossible without the old remote though. Hope this works.
Apr 22, 2013 | Building Materials
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
FOR GENIE GARAGE DOOR OPENER ICA SERIES WITH INTELLICODE REMOTE CONTROL SERIES II ELECTRONICS. PROGRAMED REMOTE FOR NEIGHBORS DOOR, WHRN NO LONGER NEEDED THE ACCESS I RE-PROGRAMED TO MY DOOR. NOW BOTH...
First you want to clear both Garage Door Openers. To clear the openers you need to locate the learn code button. This button is (usually) under the white lens cover just push it and hold it in until the red light stops flashing then do the same thing to your other opener. This clears out all remote controls that are programmed to these openers. Try the remote to make sure the units were properly cleared. Neither opener should activate if this was done correctly. After units are properly cleared push the learn code button on the opener that you want this remote to open. The learn code led will flash, then press the button on the remote once (learn code goes solid), press the remote a second time ( learn code goes out). Press the remote a 3rd time and opener should activate.
Nov 22, 2010 | Genie Company Genie Intellicode 1Button...
Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
May 15, 2010 | Genie Company IntelliCode GICT390-1BL...
Have a 3 Genie remote and the center button works in programming one garage door, but the side buttons will not work to program the other garage door. Can you help?
The other opener has to be a genie, compatible genie to be exact. An older one will not work with new devices. If it will not program it will be the openers fault not the remote. Thanks BB
Feb 16, 2010 | Genie Company IntelliCode GICT390-1BL...
How do you clear and re-enter a new code for wall mounted remote
To change the code you need to locate the smart/learn button which is near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in any 4 digit code you like and press enter.
See if this works for your car.
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxillary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
Feb 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Programming the garage door opener
Homelink Garage Door Opener Programming Procedure:
The procedure described below was successfully applied to a 2005 Jaguar S-Type.
To begin with, several attempts were made using the programming instructions contained in my Jaguars owners manual. Though the procedure described in the owners manual was straight-forward and understandable, I was unsuccessful in getting the vehicles remote to make my garage door opener function. The particular garage door openers I have are both made by Genie. Both openers utilize the Rolling Code feature.
To begin with, be sure to clear previous codes on your Jaguars garage door opener by first turning (rotating) the ignition key to the I position (first notch). Next, simultaneously hold button 1 (left most button) and button 3 (right most button) down until the middle buttons red light changes from continuous on to a rapid flash. This process takes approximately 20-25 seconds. What follows is a two part process. In the first part, get your Genie portable remote and hold it near (approximately 3 inches away from) your Jaguars garage door opener console buttons. Choose which button on your Jaguars remote you wish to dedicate to your Genie door opener and simultaneously press and hold your Genie opener button and your Jaguars opener button. The red light on your Jaguars center button (button #2) will light up and within 1-2 seconds will begin to flash rapidly. You have just completed part 1 of the two part process.
Part two: Now it is time to utilize the Learn function on your Genie garage door opener. Press the Learn button on your Genie garage door opener. The red LED adjacent to the Learn button will begin to flash. You now have 30 seconds in which to program your Jaguars opener button. Using the same button you just used in the part 1 procedure, press and hold the same button for several seconds. As before, your Jaguars red light in the middle button will light up and within 1-2 seconds, it will flash rapidly. Release the button you are programming. Now, here is the key piece of information! Once again, press and hold that same button. Once again, the center buttons red light will flash rapidly. Release your newly programmed button. This procedure proved successful in my application. Here is what has just happened. The first time you pressed your Jaguars remote button tells the Genie opener that it exists and that it is a viable candidate for making your life easier (opening the damn door). The second time you press your Jaguars remote button confirms to the Genies rolling code that your Jaguars signal is legitimate and is to be trusted from then on.
Jun 06, 2008 | 2003 Jaguar XJ-Series
Home Security Logo
421 people viewed this question
Top liftmaster Home Security Experts
Lawrence Oravetz
Are you a liftmaster Home Security Expert? Answer questions, earn points and help others
