Question about John Deere 4020 Gas & Diesel Tractor Radiator
4020 fuel lines to injectors fuel leaking around rubber boots
Does car injectors need some sort of programming?
injectors are told when to work by the computer. just install and they should be good. unless the computer or pump has an issue.
May 27, 2016 | John Deere Fuel Line To Injector Boot 3020...
80 280ZX no pulse to the injectors and No power to the fuel pump
Check fuses???
Then start at the ignition.
Unplug fuel pump and see if key on gives it the voltage at connector.
Nov 12, 2014 | John Deere Fuel Line To Injector Boot 3020...
Troubleshooting fuel injectors
Do you mean there is no compression in Cylinder 3? Do you have spark?
Jul 25, 2014 | John Deere Fuel Line To Injector Boot 3020...
How can I restart my 4020 diesel after it ran out of diesel?
Crack open the line coming into the injection pump from the fuel pump (near the top of inj. pump, towards firewall). Pump the lever on fuel pump until fuel comes out of loosened line. Tighten line. Loosen at least two injector lines at injection pump head. Crank engine with starter until fuel pulses from loosened lines. Tighten lines. Crank engine again. Engine should begin firing on these cylinders first, followed by the remaining cylinders.
Jul 14, 2014 | John Deere 4020 Gas & Diesel Tractor...
How do i fix the gas fume problem in my jeep compass
look for fuel leak around the fuel manifold area Look for cracked supply and return rubber hoses look for loose clips on hoses. Check for leaking injector lines
Jan 29, 2013 | Jeep Compass Cars & Trucks
I have a 87 ford ranger 2.9 4+4 replaced both fuel pumps and fuel pump regulator when it sits for over night it looses fuel psi so when i start it in the morning it acts like it has no fuel but after a...
Without seeing it it is a hard thing to diagnose. You could have an injector leaking, possibly a fuel line. Do you smell gas? Sometimes with fords around the fuel filter leaks because of a broken clamp. The o rings around the fuel injectors could be leaking, or one of the rubber fuel lines. If you go off road alot, you could have a pin hole in one of the rubber or metal lines. Check and get back with me and I will do the best I can to help. Hope tis helps.
Jun 08, 2011 | 1987 Ford Ranger
After removing the fuel injectors and rail to remove the manifold, how do you reinstall the fuel injectors?
the same way you took it apart. put a little grease around the rubber seals so they will slide in easier. just tap on the fuel rail while lightly tapping it into place.
Mar 28, 2010 | 2002 Honda Passport
My 1995 4runner is idling badly when i come to a stop sign. what can i do?
check all vacuum hoses look for broke crack vacuum lines.replace all spark plugs and wires.if they have been changed in a while.also clean fuel injectors using prestone or gum out .fill gas tank .put a bottle injector cleaner.in tank .drive it around several miles so the injector cleaner will clean out injectors.wait until car cool down .change fuel filter. relieve fuel pressure first before removing fuel filter.
Apr 26, 2009 | 1995 Toyota 4Runner
John Deere 4020 Gas & Diesel Tractor Radiator Logo
126 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
