Question about Rheem Water Heaters
I have a rheem mains pressure 31218015 boiler- I have just moved into a new place a now, after a few days I have no hot water
kma836
  • 7 Answers
SOURCE: boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Posted on Oct 18, 2008
  • 297 Answers
SOURCE: I need to know how to fix my boiler as i have not had this one before its worcester 24i junior and some how the mains got turned off so obviously the boiler went off but now it wont work theres a red
Manual here
http://www.worcester-bosch.co.uk/homeowner/literature/discontinued-boiler-literature/discontinued-gas-boiler-literature/24i-junior-rsf-discontinued-aug-2007-literature
All these machines need 0,8 bar minimum pressure for one.
When significant drop of pressure call qualified repair man.
If this is not your regular work you are at mortal risk.
Posted on Apr 17, 2009
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
mrhotandcold
  • 248 Answers
SOURCE: Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Posted on Oct 11, 2009
SOURCE: Combi Boiler - Hot water pressure low
I have a 1 bed flat, above an old pub. I have a combi boiler but my water pressure is ridiculous. The shower water runns down the shower head. I'v been told that the cold water feed to the building is split to two boilers, one to the pub and one to me. Im thinking of installing a shower pump in between the boiler and the shower. will this work as my friend says he has done this and it sorted his problem out. I'v looked it up on the net and everything says this does not work. Help please.....
Posted on Dec 24, 2009
I have a Rheem Stella 850 series 360 L which is one year old. I have noticed the last few days that the hot water pressure is dropping and water flow is fluctuating in and out.
Did you do back flow? Suggest you perform back wash via the hot water outlet of your heater by plugging a hose. What is the tubing size that flows thru the heating elements? If it's small, maybe you need to apply higher back pressure to remove the soil. Does it have a built in pump? If it has, check the ******* strainer, maybe it's cloaked up with debris, you never know what's in the line.
Jun 21, 2016 | Rheem Water Heaters
No hot water pressure in bathroom
bleed the system,sounds like an airlock issue
Apr 05, 2017 | Water Heaters
Cold water pressure poor in shower. Just had Rheem installed.
You might have clog in water lines.
If shower is only place where low pressure exists, then clog is probably at shower valve.
Disassemble valve and see if clog will flush out.
From there, you have to keep moving back along cold water line looking for pipe filled with sediment or elbow that has obstruction.
If pressure problem is bad at every cold tap, but doesn't affect Hot water, then clog is inside Cold line somewhere after water heater connects to cold line.
Buy a pressure gauge that connects to water hose.
Buy adapter that also fits pipe thread.
For example Brady BTG 100.
Test outdoor spigot for baseline pressure.
Open cold tap inside house and see how much pressure drops.
Close cold line and open hot tap and see how much pressure drops.
Next, move pressure gauge along cold water line.
Take apart pipes and inspect for obstruction at elbow or pipes filled with sediment.
Look for any place galvanized pipe connects to copper pipe, since this will be likely place for obstruction because of bi-metal corrosion.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pipes.
Jan 05, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Empty boiler
Turn main water off to the water heater, it may be a valve on cold side coming in to shut off. Next turn power off to the heater and drain the tank the drain will be located near the bottom of the tank.
You will need a water hose to connect to the drain to run water outside. Open a faucet hot side to allow you to drain the tank.
Upon reinstall connect the tank up and fill tank and open up hot side on one faucet at a time to purge out air from system before turning power back on. Make sure you have water flowing from each faucet's hot side before turning power back on.
Jul 02, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Oct 10, 2009 | Water Heaters
I have a combi boiler and a 'popping' hot tap
the lock nut has either come loose under the handel or the 'o' ring and stem have loosened up, might this be a delta faucet? if so replace the cartridge "stem" and the o-ring and spring you will be fine,,
Jun 09, 2009 | Rheem Tankless water heater for 1-2...
Water Heaters Logo
50 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
