Question about Toshiba 57HDX82 57" Rear Projection HDTV
Loss of sound when I go to HD mode of tv.
I lose sound when I switch to HD mode of teelevision. Picture is great but no sound. I am using motorola set box QIP 6200. Is there a special set up need for my television? I was thinking the shortcoming was my motorola set box because there was no problem when I used Cox equipment. Problem no 02. What code do I ned to input for Toshiba 57HDX82 on remote controls? What codes do I need to to input for Toshiba 27AF42 Thanks in advance
    Scholar:
  • 150 Answers
Unplug the Moto box and plug back in after 1 min, as far as the codes, which remote cable/ tv? Cable remotes vary so much you will probably have to call your provider to have them walk you through programming.
Posted on Jul 18, 2007
SOURCE:
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
I have hd picture but no sound, tv says hdmi audio unavailable
I called Verizon and exchanged my STB from a QIP 6416 to a QIP 7216 and it solved the HDMI audio problem. This looks like the fix.
Apr 05, 2009 | HP PL4260N 42 in. Plasma HDTV
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
Red Vertical Burn Line on LCD Screen
Try changing the picture setting on the television rather than from the picture box.
Sep 09, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Televison & Video
Certain HD settings won't work
no the set uses only two settings in the Y, Pb,Pr which it swithes back and forth. when a 480i,480p SD singal is detected it will switch to 480p, when an HD signal is detected it swiches to 1080i. when it swiches the picture scrambles for a second or two. to correct this in your cable box (if it's a motorola box) leave the tv on, press the power button on the box to shut down the box. next press the menu button on the box and the internal menu will show. use the cursor buttons on the box to select "480i overide" use the arrow to the right to select "streached" them hit menu to get out. hit the power button to turn the box back on.
Dec 16, 2007 | Mitsubishi WT-46809 46" Rear Projection...
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Toshiba 57HDX82 57" Rear Projection HDTV Logo
162 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
