Question about HP ProBook 4530s Notebook
HP4530s battery dischargs when turned off
My HP4530s's battery discharges when it is switched off. It discharges at a rate about 1%~2% per day (switched off) But when the battery is removed from the laptop, battery never discharges itself. It seems like laptop uses battery even it's turned off. I have noticed that HP Power assistant keeps history data about laptop on,off time etc. Off time timer works only when battery is available. There is no option in bios or HP power manager related to disabling battery usage when laptop is turned off. Could anyone please help me to solve this problem?
    Sergeant:
    Champion:
  • HP Expert
  • 427 Answers
Remove the battery when the laptop is OFF. I am not good at electronics, but I think this is normal and is NOT A PROBLEM.
Posted on Apr 17, 2013
3 Suggested Answers
  • 414 Answers
SOURCE: Windows XP start-up problem - Hangs
When you reinstall xp you will not have to reformat the drive. Just reinstall the operating system. As long as you are in safe mode back up what you need to then reinstall xp.
Mark
If you need more help let me know.
Posted on May 27, 2009
joecoolvette
  • 5660 Answers
SOURCE: Hp laptop... black screen... caps lock flashes 5
When the Caps Lock flashes, it is then being used in a diagnostic mode. 5 times flashing means a problem with the System Board.
Motherboard.
I don't doubt it.
Two common problems, all based on one issue.
Overheating.
1) Problem One;
Primer;
The Processor, and the GPU are the two hardware components that produce the most heat.
[ GPU = Graphics Processing Unit. Slang? Graphics chipset,
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
GPU,
http://en.wikipedia.org/wiki/GPU ]
It could be something as simple as foam has melted, and melted down onto the motherboard, near the Processor socket. Removal puts the laptop back into service again.
It could be much more complicated, and follow an issue that has beleaguered the HP Pavilion dv2000 series, dv6000 series, and dv9000 series.
The cooling system for the GPU is inefficient. Allows the GPU to overheat.
Constant overheating partially melts the solder connections of the GPU to the motherboard.
The graphics chipset (GPU) is mounted to the motherboard with a BGA surface mount.
Ball Grid Array,
http://en.wikipedia.org/wiki/Ball_grid_array
To explain the BGA surface mount;
Compare to an older Intel Pentium 4 processor, and it's Socket 478 processor socket,
http://en.wikipedia.org/wiki/Socket_478
The processor has contact pins on the bottom. (478 of 'em) These line up with matching socket holes in the Socket 478 processor socket. (478)
With a BGA surface mount there are no contact pins, nor socket holes.
Solder Balls take the place of the contact pins, and Copper Pads take the place of the socket holes.
The graphics chipset's Solder Balls, are lined up with the matching Copper Pads on the motherboard.
Heat is then applied at a specific temperature, and length of time.
This procedure melts the Solder Balls, and solders the graphics chipset to the Copper Pads.
(Motherboard)
With constant overheating the solder connections that were created, start to melt. This creates a poor connection.
The professional method to repair this problem, is to use a BGA Rework Machine, to Properly re-solder the connections.
Due to the location of repair shops that have a BGA Rework Machine, and the C-O-S-T, many are attempting to perform the procedure with a non-professional method.
A thin metal shield is cutout in the middle, for the graphics chipset. This shield is set over the graphics chipset, and lays on the motherboard. Heat is then kept just to the graphics chipset, and the other components on the motherboard are protected.
Heat is applied with a propane torch, or a hot air gun, (Not hair dryer), in a circular (Spiral), pattern to the graphics chipset. With a more proper method used, the tip of a thermometer that can read this heat range, is laid on the chipset, and is used to keep the chipset at a specific temperature.
(Too much heat will burn up the chipset. Too little will not properly remelt the solder connections. A Cold Solder joint, or joints, will result)
The heat from the heating instrument, (Propane Torch/Hot Air Gun), is rotated around in a spiral pattern on the chipset. Constant moving around to distribute the heat evenly.
(You do not want a 'hot spot')
When the specific heat range is met, the heating instrument is slowly moved away from the chipset.
Move up an inch or so, keep spiraling. Then move up another inch or so, and keep spiraling the heat source. Slowly move up in increments while spiraling. S-L-O-W-L-Y back away. Method is used so that the chipset slowly cools down. Otherwise a cold solder joint, or joints, could result.
(Right back to where you started)
This link is to a video that shows one style of the procedure. It is not an advertisement for the video, just linked for the procedure information,
http://www.youtube.com/watch?v=bnkQNmKauEc&feature=pyv&ad=5823851286&kw=DV9000
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Nov 12, 2011
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
I havn't used my UM300 in only two days, last time it was working pretty well ... better than ever, today morning i woke up and tried to use it, but all im getting from the amp is a buzz in a very low...
Dead battery or disconnected power adapter. Leaving cables connected discharges battery in a day as this is what switches the battery on. (The input cable)
May 24, 2011 | Behringer Um300 Heavy Metal Distortion...
Where is the button to turn the discharge from vertical to horizontal? The manual states to "simply push the positioning button and rotate" - can't seem to locate the button!
Press the positioning button located on pump housing and rotate discharge port to desired position.
Note: the Discharge port will only rotate 1/4 turn.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Ford radio 6006 CDC, fitted in Fiesta ST, fault discharge battery
Was wondering if anyone can help got a Cdc error on the stereo 6006? Also wondered how to load the cds into the stereo?
Apr 24, 2010 | Car Audio & Video
Photosmart M447 wont turn on.
50 pictures is way more than I get from this camera per battery charge. It draws 500mA when on, and 1000mA of current from the batteries when charging the flash so battery life will be short.
It also has a design flaw that says low battery and shuts off even when the batteries are 95% charged.
Be aware that rechargeable NiMH batteries self discharge at a rate of about 1% per day. They have a strong Amp-hour rating but need to be freshly charged.
IF the camera won't turn on at all when trying NEW 1.6V Lithium AA's (those are the strongest AA's made) or freshly charged 1.2V NiMH batteries and you know they are charging up to at least 1.35V per cell (they charge above their rating) then the camera itself has a problem.
Even if you get it to work, this is one of the lowest quality camera's made. I have quite a few decent camera's and I've never seen anything like this one, it's rated for 5Meg but has less resolution than an old 2Meg Canon. I paid $39 for it new on 3-2010 and I sent it back because it has no purpose since it can not take a clear picture.
Sorry but the only solution with this camera is to get something better (Canon, Sony, Nikon).
Aug 29, 2009 | HP Photosmart M447 Digital Camera - Silver...
My aims 2000 pure sine wave inverter is pluged to 2 240amp/h 6 volt batteries. When | plug in a 1800 watt hairdrier i get an alarm as if the batt. were to low. they are new and at full charge. is the load...
Your inverter has a peak of 3000 watts rating and should power that hair dryer. Make sure your batteries are in good shape. The inverter can only put out what it takes in. 1800 watt demand on the inverter requires 1800 watts from the batteries.
Jul 14, 2009 | Inverter Aims Pure Sine Wave Power...
New BN-V428U battery
BATTERY TIPS
Now a days in LITHIUM BATTERIES are used no memory effect
always charge battery for 16 hours when first use new
never keep ur battery fully discharged for long time when u store ur camera always keep it half charged or fully charged when storing for longer period
it is good to fully discharge once in a month but dont make it ur habit
pls rate me FIXYA for help
Apr 13, 2009 | JVC GR-D50 Mini DV Digital Camcorder
What is the difference between the available AA battery chemistries?
AA batteries are available in four basic varieties: Alkaline Nickel-Metal Hydride (NiMH) Nickel-Cadmium (NiCad) Photo Lithium (Li-FeS2) Alkaline and photo lithium are non-rechargeable, while NiMH and NiCad are rechargeable. Each has advantages and disadvantages. Non-Rechargeable vs. Rechargeable: Rechargeable batteries are desirable from an environmental standpoint because they are reusable. Self-discharge refers to the fact that batteries lose energy when unused and even when not in a camera or other device. Rechargeable batteries tend to have relatively high self-discharge rates, approximately 1-2% per day for nickel-based batteries. Non-rechargeable batteries generally have very long shelf lives and extremely slow self-discharge rates. This makes non-rechargeable batteries a better choice for infrequent usage. Non-rechargeable batteries are available fully charged in stores all over the world, which makes them a convenient choice for travelers or customers who have dead rechargeable batteries and no time to recharge. Photo Lithium Batteries (Li-FeS2) (non-rechargeable): Photo lithium batteries will yield the longest battery life of any AA battery, surpassing NiMH by 50-100% and surpassing alkaline by 100-500%, depending on the load. While they are more expensive than alkaline batteries, their additional energy capacity makes the cost the same or less per shot than alkaline batteries. Nickel-Metal Hydride Batteries (NiMH) (rechargeable): NiMH batteries are the lowest cost overall solution for users that take a lot of pictures (more than the equivalent of a roll of film per month) or use a lot of high-power features. The largest disadvantage to NiMH batteries is their fast self-discharge rate of 1-2% per day whether the batteries are in a camera or not. NOTE: NiMH batteries need to be completely charged and discharged a few times when new to achieve their full capacity. Rechargeable batteries will eventually fail. If you have been getting acceptable battery life and then see a decrease in life, either quickly or slowly over time, a worn-out battery may be the cause. Storing or charging the batteries in high temperature conditions will accelerate this potential failure. Alkaline Batteries (non-rechargeable): Although the cheapest and easiest to find, alkaline batteries yield the worst performance of all the chemistries in a digital camera. They lose capacity at high power drains and at low temperatures. Skiers and other winter outdoor enthusiasts may find them unsatisfactory. Alkaline batteries are frequently available in two types: High drain (ultra, titanium, maximum etc.) Regular The high drain versions are a premium product designed to operate better under heavy loads than the standard product. However, there is a trend of major brands to increase the performance of their standard battery to b
Aug 30, 2005 | HP Photosmart 120 Digital Camera
HP ProBook 4530s Notebook Logo
81 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
