Question about Imperial IFS40 Deep Fryer
How to convert imperial deep fryer from nat gas to lp gas
bigg t
  • 640 Answers
SOURCE: Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Posted on Sep 04, 2008
  • 3 Answers
SOURCE: GAS VALVE TIMING OUT
I had a simular problem. The gas company disassembled the pilot light and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Posted on Oct 29, 2008
  • 125 Answers
SOURCE: Imperial deep fryer IFS40 pilot lights, turn on
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Posted on Feb 21, 2009
bigg t
  • 640 Answers
SOURCE: I NEED A PART´S LIST OF Imperial IFS40 Deep Fryer
Go to 3wire.com,register,its free and type your model in.
Posted on Mar 22, 2009
hiltonjug
  • 612 Answers
SOURCE: imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
Posted on Oct 19, 2009
Cecilware fms40 fryer convert to lp gas
Most NatGas devices will convert to use of LP by changing the orifice.
GRINDMASTER CECILWARE F177A ORIFICE 52 1 16 LP GAS
Oct 05, 2015 | Cecilware FMS-40 Deep Fryer
Imperial ifs40 fryer suiting up.
If you don't know that you are doing you should buy them. You need one for each burner, 3 or 4 for most models. Yes they can be drilled out going only one way, using lettered drill bits that are hard to find. The regulator on the back normally has to be adjusted also. If either is wrong, the flame will be to big or to small to heat correctly. At least buy one orifice and check the size hole, they are not expensive $5 -$10 if you do a little searching for a good price.
The Part Numbers are:
Orifice - NAT. Gas 1625-36
Orifice - L.P. Gas 1625-51
You MUST use Lettered drill bits for size, Like A-Z If it was drilled with any normal size bits 1/16 type bits it will NOT be correct! There should be a number stamped on the orifice, unless it was drilled out. Most people never mark the door that the gas type was changed, causes all types of problems for the service men.
Can you give more details to your problems? I couldn't find the hole sizes right off, but have seen it listed.
Apr 07, 2015 | Imperial IFS40 Deep Fryer
Can I tell just by looking at a deep fryer if it's nat gas or propane
It should be listed on the label unless it was changed at some point. The only way to tell is to use numbered drill bits to see what size hole is in each brass orfice of the burners, usually 3 to 5. The manual will list the orfice size for LP or NAT by the fryer BTU output. Most manuals can be found online, if you don't have a copy. This will require removing part of at least one burner to check the hole size. New orfices are normally about $20 each, most are marked on the side of the brass orfice. Note: some people drill out the holes to convert LP to NAT gas. Don't trust what is marked on the orfice, be sure to check with a drill bit. Small numbered bits can be hard to locate in most hardware stores. Found mine at Harbor Freight Tools.
Sep 23, 2014 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Can I tell just by looking at a deep fryer if it is nat gas or propane
NO.
Imperial Fryers have the Type of Gas on the Information plate on the inside of the door..
Call imperial if you are stuck
http://www.imperialrange.com/contact.php
Sep 23, 2014 | Imperial Kitchen Appliances - Others
Flames cominhg out of flue
Hi I use to repair every kind of restaurant equipment under the sun..maybe I can help...Is this a new install of the fryer and it never did this before, or did this just start do this..If a new install, the first thing I would check is the gas regulator and see if it is for Nat gas or Lp gas, and find that out..cause it has to match what you have, comming into the building..usuall the gas valve has a sticker on it that says what the water columbs are like for Nat it is like 3-6, and for Lp(propane) it is like 5-12. Ive seen customers buy a used fryer, and install a LP fryer in a Natural gas build, and the valve lets too much gas to the burners, and it will shoot flames out the top..then you would have to buy and convert a gas valve, or use parts to convert it..let me know further..
Apr 20, 2014 | Pitco Frialator SG14 Deep Fryer
Want to convert to lp gas. has a wr safety valve with a oem #1173wr
To convert a natural gas fryer to LP, you have to change out the orfices... We can order the kit for you and have it shipped in 1-2 days...Call Ray at Restaurant Equipment Outlet, 888-542-5959, with model and serial number of your fryer... Thanks, Susan REO Cincinnati, Ohio
Sep 08, 2011 | Imperial IFS50OP Deep Fryer
From natural gas to propane
Page 3 shows your conversion kit part numbers provided by PARTSTOWN
The pilot light has to be converted to LP. The burner orifices must be swapped out and the gas valve must be converted. from Nat to LP. Do your swap out and open your air shutters. Light it off and tweak the air as needed then party on!
Jul 26, 2011 | Imperial IFS40 Deep Fryer
I have purchase 2 used FMP 40BSS fryers - originally Nat Gas - i want to convert them to LP - what is needed and can i do it myself?
To convert these to LP you must downsize the burner orifices and the pilot orifice. Also you must change the regulator on the gas valve to LP. Easy job.
Tom
Aug 14, 2010 | Cecilware FMP40BSS Deep Fryer
Do you have instructions on how to convert a deep fryer to LP I have a Pitco 35cs I need to convert to LP
Visit http://www.middleby.com and go to PITCO web, you will be able to locate there the nearest authorized parts dealer on your area and ask for the conversion kit (from nat to lp). The gas valve conversion kit consists of spring, cap and instruction manual. you also need to replace the burner and pilot orifice, Nat pilot and burner orifice have larger bore than lp.
Apr 06, 2010 | Pitco Frialator 35CS Deep Fryer
Change from natural gas to propane
1.You will need to change the pilot orifice and the burner orifices
2. You may need to change the gas control valve. Some gas control valves are made for natural gas and some are made for LP. They have regulators built-in, that deliver the correct pressure respectively. Natural gas is 3.5 inches of water column, LP is 10 inches of water column.
Some manufacturers sell kits to change the spring in the regulator from Nat to LP
You would need a parts breakdown on the specific model number of your fryer to find the parts you need. Hope this helps.
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Imperial IFS40 Deep Fryer Logo
71 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
