Question about Dual XINBP212 Car Subwoofer
My dual subwoofer is a 4 ohm but my amplifier is a 2 ohm. when i hooked them together the red light on my amplifier came on. it says protect by it. the green light means power. what do i need to do to
Amplifier is a 2 ohm. The red protect light stays on instead of the green power light.
4 Suggested Answers
  • 21 Answers
SOURCE: new Dual XIA3145 2/1 LED glows red, guide claims speaker problem
look at these and only these... power or ground...either your power wire has grounded out somewhere (ud be surprised) or youdont have a good enough ground....i would check the ground first....hopefully this helps
Posted on Jan 27, 2009
smarthome2
  • 1114 Answers
SOURCE: I Have a set of Dual XNBP12D Car Subwoofer and curious about if
You need to look at the specifications of the speakers and the specifications of the amp you are hooking them up to. For example: The speakers could be 8ohm drivers wired in parallel which would produce one connection at 4ohms. Most "bridgeable" car amplifiers are very stable at 4ohms. However you must first find out if the amp is "bridgeable" which means it's taking both outputs and adding them together for one monoral output.
Now to the contrary: If both speakers are 4ohms wired parallel, this would produce a 2ohm load and alot of "inexpensive" amps will not work efficiently in a 2ohm load since it creats alot of heat! and will cause an amp to shut down.
Get your manuals out and look at the specifications for impedance.
Lastly, you've got a band-pass box that is specifically designed for a mono load. (one channel) since there is no internal divider between the subs. If you were to run this box in 2 channel or "stereo" the subs would not be moving in unisome and fighting each other for "airspace". Hope this helps
Posted on Jun 15, 2009
  • 501 Answers
SOURCE: i have 2 15 type r subwoofer and 2000w alpine
Check the specs on your speakers and the amount of cubic space it needs to breathe and amount of porting required and then check the box to see if it meets that requirement otherwise if it doesn't it will sound like **** and be highly distorted.
Posted on Dec 10, 2010
Can I wire 2 dual 2ohm subwoofers to a 1ohm load and yes my amp is 1ohm stable I want to get the max rms from my amp
King Chambers,
It would be optimal to have subwoofers that are Dual 4 Ohm. However I am going to tell you the most optimal way to hook up the combination you have to extract the most power out of your amplifier.
You will need to wire each subwoofer in series by taking the positive from one coil on the subwoofer and connecting it to the other voice coil on the same subwoofer; then take the left over positive and negative and hook that to your amplifier.
You will do the same with the other subwoofer. This will give you a 2 ohm load. If you had dual 4 ohm coils then we could get you down to a 1 ohm load.
Mar 13, 2016 | Dual Car Audio & Video
How do i wire alpine swr1243d subwoofer
There are a couple different ways you can wire up this speaker as it is a DVC speaker. Duel Voice coil, it has two + post and two - post. A dual 4-ohm voice coil subwoofer with its coils wired in parallel presents a 2-ohm load to your amplifier. Since an amplifier produces more wattage at a lower impedance, the parallel connection ensures you'll get the most output from your amp.
Series wiring lets you configure multiple woofers to one amplifier at an acceptable impedance. Wire both coils in series for an 8-ohm impedance, and then wire two 8-ohm subs together in parallel for 4-ohm total impedance.
You can wire each voice coil to a separate channel of your amplifier, if you prefer not to bridge your amp. Independent wiring is a nice option if you're wiring two DVC subs to a 4-channel amplifier - one voice coil per channel
Depending on what you are hooking it up to i.e. a mono amp or a bridged four channel amp. I can tell you post to wire exactly if I know how you want to hook it up and what ur hooking it up to.
Sep 15, 2014 | Car Audio & Video
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
I have 2 10" Kicker Comp Subs
That amplifier is only rated at 150 watts at 4 ohms, or 300 watts at 2 ohms. Not a very strong amp to run 2 kicker comps. My guess is you have the subs wired wrong for your application. There are 2 types of subs, one is a dual 4 ohm, and one is a dual 2 ohm. Most people bridge these coils together and that cuts your ohms in half. For example. Lets say you have the 10cvr104 subs. Thats the dual 4 ohm sub. You wire the coils together in parallel, now its a 2 ohm sub. You have 2 of these subs running off of your amp, if they are hooked up in parallel, now you have a 1 ohm load, out of the amplifiers normal operation. Your amplifiers internals heat up really quick and there is a thermal overload, putting your amplifier into circuit protection mode. My suggestion for wiring your subs is as follows: for each speaker, wire the coils together like this- positive coil1 to negative coil 2 and negative coil 1 to positive coil 2. That is called running in series, and doubles your ohm load. Next, we need to wire the speakers together properly to hook up to your amplifier. For this, since the coils are hooked together, you only need to use one set of terminals from each sub. And take the positive from sub 1 and hook it to positive of amp. Take negative sub 1 and hook it to positive of sub 2. Take negative of sub 2 and hook it to negative of amp.
Aug 30, 2012 | Rockford Fosgate Punch 301M Car Audio...
How do you hook up the speaker wire to the ab sub out and what is the best way to hook them up at what ohm
Not sure what you mean by AB but being that this is a monoblock or 1 channel amplifier you can only hook it up 1 way. Verify the polarity from your speaker box. + to + and - to -. As far as your impedance is concerned this amp is stable to 1.5 ohms but for this case we will assume you have two 4 ohm subwoofers. When you parallel these together you will have a total effective load of 2 ohms on the amplifier. This is a stable operating impedance for the amp.
Other impedance options are:
two 8 ohm speakers = 4 ohm load
three 8 ohm speakers = 2.66 ohms
If you have dual voice coil subwoofers then parallel the coils on each sub + to + and - to -. Depending on the impedance of each sub you may then have to wire the individual subwoofers in series. Here is an example.
2 dual voice coils with 4 ohm taps
Each subwoofer with the coils in parallel would be a 2 ohm load if you were to then parallel the two subwoofers together you would have 1 ohm total load on your amp. This is BAD for your amp. Your option is to run the subwoofers in series.
To run the speakers in series is simple. The + from one speaker and the - from the other will be connected to the amp. The other + and - from the speakers will be connected together.
Here is a wiring diagram from kicker.
http://www.kicker.com/dvc_wiring
Jun 11, 2011 | Jl Audio Slash 500/1 Car Audio Amplifier
I have a sony xm-2002gtw and i want to know if i can hook two 2-ohm dual subwoofers up to this amp and how i have 2 solo baric 12-inch.
200W x 2 @ 4 Ohm
500W x 1 @ 4 Ohm
This amplifier cannot handle a load lower than 4 Ohms in stereo or bridged mode.
If the subs are Dual 2 ohm - You cannot wire a 4 ohm load with (2) subwoofers.
Only 8, 2, or 1/2 ohm loads are possible with (2) dual 2ohm voicecoils
Thanks!
Feb 15, 2010 | Car Audio & Video
I have a ly1440 amp how can i wire it to my hk15x2
This subwoofer has (2) 2 Ohm voicecoils.
Which means you will only be able to wire a 1 Ohm or 4 Ohm configuration for your amplifier.
The Model # you listed for the amplifier is not a valid one.
If your amplifier is 1 Ohm mono stable...
you wire both (+) Sub to amp (+)
and both (-) on Sub to amp (-)
This is PARALLEL wiring and lets the amplifier SEE a one ohm load
If your amplifier is NOT one ohm mono capable - your only other possibility is a 4 Ohm load.
Wire from (+) on amplifier to one (+) on the sub
Then Wire from (-) on amplifier to the OTHER terminal's (-)
You will have one (+) and one (-) left on the subwoofer - wire them together.
This is SERIES wiring, and nets a 4 ohm load for your amplifier.
There is no other configuration for wiring one Dual 2 ohm sub.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Aug 07, 2009 | MA Audio HK15X2 Car Subwoofer
Let our Experts solve your "My amp lights up like normal then protection light red comes on and turns the amp off resets and tries again. What would be my course of action
disconnect all wires (including RCAs)
reconnect positive, ground, and remote.
Turn amplifier (car) on.
If it goes into protect mode again - there is an internal fault that requires professional repair.
If the amplifier idles as normal - turn off the car. Plug in RCAs & re-try
Failure? - replace RCAs as they may be pinched or faulty.
Lastly if all connections are made and amplifier idles without going into protection - you need to concentrate on your load (subwoofers).
Be sure they are wired properly into a resistance that amplifier is rated.
The lowest impedence that amplifier is rated is 2ohm.
That is possible with (2) 4 ohm subwoofers wired in parallel....
(4) 8 ohm subwoofers wires in parallel...
(1) Quad 1 ohm subwoofer...
or (1) Dual 4 ohm voicecoil subwoofer.
Any other combination will result in an impedence too low for your amplifier.
Next:
Using an OhmMeter (Digital multimeter set to Ohms 20) test each voicecoil against its advertised resistance. It should be CLOSE +/- .5 Ohms.
Any other reading means the voicecoil is blown.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 27, 2009 | Kicker (ZX750.1) Car Audio Amplifier
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 29, 2009 | American Pro Car Audio & Video
New Dual XIA3145 2/1 LED glows red, guide claims speaker problem
Jan 27, 2009 | Dual (DBXPA6100) Car Audio Amplifier
Dual XINBP212 Car Subwoofer Logo
24 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
