Question about Emerson Black Microwave Oven
? MODEL NOT FOUND
I can not find my model number on the web-site, I have MWG9111SL, I just need to know where the light bulb is to replace, I have only had this microwave for less than 6 months, should the light already be blown?
  • Emerson Master
  • 9,086 Answers
Your owner's manual is here.
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jan 29, 2009
We have a Panasonic microwave 1200 we've replaced the bulb and switch but still no light every thing else works
I would need to know which light, the cooktop / work lights or the inside lights. And I would need to know which switch you replaced.
I would need the FULL model number & "FCC ID" number from the tag in cooking cavity or around door frame or control frame or on back.
For more free DIY and other help & advice, feel free to contact me via my site. Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 13, 2017 | Panasonic Microwave Ovens
Light Bulb Blew - blue spsarks. Replacement does not work. shorted out
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Or you can order a new control circuit board from the
Sears Parts Direct Web site.
Just enter your model number there.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
Jan 22, 2011 | Kenmore 80412 Microwave Oven
I need the owners manual for model number mwg9111sl
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | Emerson Microwave Ovens
Need new lamps for Sharp Microwave Oven Model R-7650. Information on bulb is 125V20WS.
The original part number was RLMPS0001YBE0 but it is listed as no longer available.
If the bulb unscrews from its socket, then you should be able to remove it and take it for a generic replacement at a home improvement center (like Lowes) or the light bulb section of Wal-Mart.
If its is one-piece unit with bulb and socket that are inseparable, then you'll need to sub that with a similar type assembly at a local appliance parts company. You can see the Yellow Pages or yp.com to find those.
Dec 21, 2010 | Sharp Microwave Ovens
I need an owner's manual for an Emerson Microwave Grill - Model #MWG9111SL. Mfg. July/08. Do you know where I can find one?
It's here:
http://www.emersonradio.com/owners/MWO%20manual/Manual%20of%20MWG9111SL/MWG9111SL.pdf
Sep 07, 2010 | Microwave Ovens
Light bulb replacement
the light bulb is usually in cavity behind the control board.to access that first remove the outer cover of the unit by removing all screw at the back.after removing the cover u will have access to yhe cavity behind the cntrl board and the light bulb.....good luck.
Aug 19, 2009 | Emerson MW8168B Microwave Oven
I need a manual for Emerson Microwave mwg9111sl
When replacing the bulb in an Emerson, Microwave. Model mwg9111sl. Can you replace the bulb or the socket and bulb?
Jun 01, 2009 | Emerson MW8168B Microwave Oven
Need cooktop replacement bulb for Kenmore
Search the web site www.searspartsdirect.com Once you find the information, you can purchase it where ever you choose. If you found this information to be helpfull, please rate my solution. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
Work light and night light do not work on Sharp Carosel R-1481
> Work light and night light do not work on Sharp...
Thanks for giving us the model number.
We regularly repair these R1481 control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Nov 22, 2008 | Sharp R-510HW Microwave Oven
Emerson Black Microwave Oven Logo
83 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
