Question about Pool & Spa
Can't get my pool water the right clarity no matter how much chlorine & chemical wonder if I need to change the sand in my tagelus 230
Have been using granular chlorine always never had this problem before
  • 372 Answers
Changing the sand should do the trick. Those relatively small filters can load up with debris and oils quickly. The pump doesn't always have enough power to effectively rinse out the filter during backwash, especially if the sand is old and loaded.
One thing you may want to do is use a flocculant to drop all the suspended particles to the floor, then vacuum to waste. This will prevent all that dirt from getting into the new sand.
Posted on Jan 20, 2013
  • 19 Answers
SOURCE: How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
Posted on Apr 30, 2009
  • 272 Answers
SOURCE: no chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Posted on Jun 01, 2009
  • 297 Answers
SOURCE: i have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Posted on Jul 12, 2009
  • 297 Answers
SOURCE: Algae forming in pool
ok here is the scoop first of all the generator will not raise your PH
Hard water rain and bad pool maintainence raises PH
Yes you need to add chemicals Salt water system is to just not need to physically pour chlorine in
on to your problem, you need to get a test kit and make sure you get your salt to the level it needs to be at ( about 10 bucks for 10 tests)
3000ppm is a good level any higher and you will definately have a salty taste any lower than 2500ppm and your generator will not produce enough chlorine
If you are close but under 3000ppm add 10 pounds of salt at a time till you get to 3000 making sure you filter/curculate only ( no generator ) for at least 24 hours even if you do not see the salt it is not mixed enough
If it is too high then let out 2-4 inches of water re-fill and filter for about 4 hours and then check
once your salt is proper then go on to getting your chlorine level to 1.0-3.0
this will never be achievable on a daily basis so be ready to deal with ph also
chlorine will fluctuate greatly depending on #of swimmers per day, sun light,heat, and rain so as a general guide start out with 4 hours of chlorine generation and see what that does for you for that specific day you may have only needed 2 hours or maybe you needed 6 hours you are the best judge of this once you become familiar with what works for your situation
now for ph it is some what controlled by chlorine level so once you get it set while the chlorine is good the ph will rise and fall with the chlorine level Usually not enough to make a difference unless you have to add hundreds of gallons of water or if you have so much rain that it over flowed your pool so check your level and either use ph up or down for your situation you need to be close to 7.4 or so
Now to really address your problem ( ALGEA )
most pool owners do not realize just what it takes or is involved in proper pool care.
A pool will form algea for a # of reasons but if you filter proper;y it will remedy other problems that could occur
first you need to realize that a pools water needs turned over at LEAST 3 times a day ( swimmers or not ) by this I mean (and you gave no specifics on pool size) Lets use generic #'s If you have a 4000gallon pool and a 2000gallon pump you need to run your filter for at least 6 hours you do the math for your size pump and gallons of water
Now this is over and above the chlorine generation so as you see it is important to stay on top of the maintainence especially if no one uses it since that creates curculation
well after all of this add a good chlorine stabilizer and that will help with holding your chlorine level also
JUST REMEMBER FILTER FILTER FILTER
especially since the intex filters are not strong enough for the size pool that comes with it
And I forgot to mention you should spray the paper cartridge with the garden hose on high from top to bottom EVERY DAY
Posted on Jul 30, 2009
  • 297 Answers
SOURCE: CLOUDY SALT WATER POOL
salt does not solve your problem.
People do no realize that all the salt does for you is that it eliminates having to pour regular chlorine in.
Everything else stays the same as a normal pool with just plain ole h2o
The dilema is that intex filters are to small for the job that needs done especially in your case now that you have the dreaded green monster
your solution is to first get it cleared up
shock your pool with 2 gallons of liquid chlorine and then filter filter filter
You will need to brush the dead algea and vaccum once or twice a day for a couple of days and you must clean that cartridge 3-4 times a day with the garden hose
you will be surprised how much green it will trap
once pool starts to clear and the chlorine level starts to come back down from Mars you can start using your generator again.
you will need to find the amount of time thatorks for you but 3-4 hours will not cut it in the hot weeks
Chlorine consumption is due to #of bathers, heat ,sun, rain so any given day will dictate a different amount of generation needed keep it high so you do not get algea again about 3.0
you also got algea because you were not stiring up the pool enough you again need to filter filter filter every day
try to find some of my other postings with more specifics
Posted on Aug 13, 2009
Tip
Solving Salt Water Pool Problems
The big problems with salt water pools is actually the salt in the pool water itself. Salt water chlorination has many benefits over standard pool chlorination methods, but with a salt in the pool system there are significant drawbacks, hidden expenses, problems, and potential dangers. The best way to enjoy salt chlorination is to get the salt out of the pool. The Chlorine Genie Pool Water Management System does just that. In fact the system can produce and take care of up to 5 important pool chemicals for you. If you are fed up with salt water pool problems and ready for the cutting edge in pool water sanitation, check out the new advantages of Chlorine Genie's Chlorine Generator Technology.
Chlorine Genie Inc Martinez 94553 The Ultimate Pool Chlorinator
Check out the Pool System Videos on YouTube at: Chlorine Genie
Get Social and Join the Pool Party at: https://about.me/chlorinegenie Chlorine Genie on about me
on Nov 08, 2016 | Pool & Spa
First thing to do about chemicals for above ground sand filters
the values I set for my customers pools is as follows:
chlorine 1.0 - 3.0 ideal
ph 7.4
alkalinity 100 ppm
calcium 200 ppm
stabilizer 50 ppm (saltwater pool 25 ppm)
These values will provide balanced swimming pool water
Jul 01, 2014 | Blue Wave Sandman Above Ground Sand Filter...
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
GASKET CHANGE: What steps should I follow to change a leaking gasket on the diverter on the valve of my DAVEY TAGELUS 230 sand filter?
make sure the valves on the outside of the pool are closed so when you open up the valve to change the gasket the pool water will not continue to run out of the filter.
Once you are secure about water flowing out of the pool through the filter you can remove the bolts holding the filter body together and change the gasket.
Rod
US Parts Center
Feb 06, 2013 | Pool & Spa
Hello I have a 15x48 intex above ground Easy Set pool and saltwater system. All was working well for about a week and a half. I couldn't get my ph and TA levels right so I brought a sample to my...
I've been running mine for 2 years without checking anything other than the free chlorine level and it's always crystal clear without adding NO CHEMICALS. Make sure you have the correct salt level and start the unit. Take a water sample at the discharge after the chlorinating light comes on and check to see if it measures chlorine. Should be slightly yellow color. If so, your unit is producing free chlorine.
Jul 13, 2011 | Intex Automatic Salt Water System for ...
I just ordered and received a 2500 filter, set it up, turned it on, and nothing....motor noise, but no water movement. What am I doing wrong? AS far as I know, I did what I was supposed to. ??? Pools...
1 - Double-check that your water level is above the hose that sends water from your pool to your filter. If the hose has even the tiniest crack, air could be getting sucked in & causing your filter to lose its prime.
2 - If you have not already done so, slowly twist the top of your filter house to loosen it (do this while your unit is on but keep a tight grip on it...once the water pressure hits it, it can push it off completely). You should hear air escaping from the unit. Once water begins coming out, tighten the top back down. Removing the air should 'prime' your filter.
3 - If you've tried this & it didn't work, try putting your filter on a level raised surface (possibly a chair or a sturdy box) at a level about equal to the hose that brings the water from your pool to your filter. Also, try putting it it as far away from your pool as your hoses will allow.
4 - If none of this works, it could be that you have a defective unit. Or, perhaps some other readers will have additional suggestions.
5 - Start saving up. As soon as you are able, purchase a Sand Filter & a Saltwater Chlorine Generator/Saltwater System. I don't know how big your pool is, but mine is 18' x 4' and holds approximately 6000 gallons. The first 3 years I had it, my children & I spent more time cleaning it than swimming in it - literally. (Once we'd shock it, we had to wait 24 hours to swim. By then, it needed a clarifier or ph + or - :-( ) My mom kept telling me that people she worked with had converted to saltwater & were just loving it. I thought that sounded like some sort of lengthy & expensive process & was leary. In the meantime, my sister-in-law was given a sand filter & she raved about what a great difference it made. I began checking online & ebay had the best prices (by far) on the sand filters, but they were still going for about $300 so I waited. My local Wal-Mart had the saltwater chlorinator for $199. It was hard for me to justify paying $500 to convert the pool (especially since I'd gotten the pool at Sam's for only $300 to begin with! Finally, though, I got so sick of having a pool we couldn't enjoy, I did it. I won an auction on a sand filter on ebay for right under $300 and a chlorinator fro $115. I got them in within a couple of days of one another & hooked them up. I got the sand at Lowe's for about $7 & the salt (also at Lowe's) for about $5. I put in the salt & stirred it around with the skimmer-pole. The directions said to wait about 24 hours for the salt to dissolve, but my pool was green & I was tired of waiting so after about 3 hours, I turned on the filter. I let it run for about 5 minutes then turned on & programmed the saltwater chlorinator to operate for 12 hours. That was about 5pm. By the next morning, the water was as clear as when I'd first filled it up. WooHoo!!! That was over 1 year ago & I've just now added my second 40lb bag of salt. Water is still clear - well worth the investment! The only thing I would recommend doing differently is the way I got the saltwater chlorinator. I recommend paying the little extra to get a new one. The one I got off ebay was great - but it only worked for one season. For no apparant reason, about a week ago, I found the power off & could not get it to power on. Wal-Mart has them for $169 this year. Don't know if you have Atwoods where you live, but I just got my new one there for $159. I didn't even hesitate this time...I knew it was more than worth it. No more filter cartriges, no more shock, no more clarifier, no more ph -, no more ph+, no more green water...just a lot more fun in the pool!
Just so you know, in case you do save up & go to sand & saltwater...the filter I got is a 2hp 22" tank. It either pumps 4000 or 5000 gallons per hour - I don't remember for sure which. I do remember, though, that whatever it is, it's 1000 gallons more per hour than the chlorinator specifies but they work GREAT together. I searched ebay for "2hp 22" sand filter" (not in quotes) to narrow down the search results. There are a couple different brands that mostly come up - Hayward & Clearwater, if I remember right. I got a Clearwater, but they probably work the same.
I know you're asking for advice about the filter you already have, so I apologize if the information I've offered is unwelcomed. I just wish I'd switched my pool years earlier than I did. I would have saved a ton of headache, hassle and, in the long run...money.
Jun 20, 2011 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
Cloudy water
are you making chlorine? If not ... get your chlorine level up to 3 PPM with dry chlorine and make sure your salt level is correct and try again. What about cyanuric acid level? should be at 80 or so ppm
Jul 02, 2010 | Intex Automatic Salt Water System for ...
Cant figure out where to put chlorine/chemicals
add chlorine to the water in the pool you might try a pool supply store for information reguardind ph of your pool and how to mix chemicals
Jun 21, 2009 | Intex Krystal Clear Model 635 Pool Filter...
How do i change the sand in the hayward e1001542s
we have changed the sand in our filter but now we cant get the back wash to work we have a davey tagelus 230 i need a diagraham to show how to put the muliti flow value on again
Oct 26, 2008 | Hayward Pro Series 18" Above Ground Pool...
Pool & Spa Logo
95 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
