Question about Shopnbc DURABOOK U12C 12.1IN CONVERTBLE NOTEBOOK
Bios Reset U12C durabook
Procedure to reset Bios
Durabook T7M no access to BIOS
Keep trying until the keyboard is ID'ed. Unplug, remove battery, plug in, reboot. Is there a reset button?
Jan 25, 2013 | Computers & Internet
Durabook. I need a master password to get in. I cannot access with Username. I also don't know the password.
Try this:
In order to reset the Master BIOS password on a durabook, you need to remove the CMOS battery and leave it out for a period of time. This will reset everything and allow you to enter the BIOS screen again.
Jan 03, 2013 | Computers & Internet
WhaT DO I PUT IN BIOS TO DO A FACTORY RESET
This may work.
Remove the BIOS battery for 20 mins, replace the battery and it will return to the factory settings.
Go into the BIOS configuration and set the Date & Time.
Oct 20, 2012 | Intel Durabook V38263 Notebook
Hello - i need the master code for durabook notebooks because i forgot my password and cant enter the bios setup please help
You can find the User Manual for the durabook here http://www.durabook.com/download/manuals/N1400_ALL_US.pdf
Hope this helps.
Feb 18, 2011 | Computers & Internet
Which function key do i press for a master system reset?
crtl+alt+del
if it is a asus theres a reset button on the bottom of the laptop 14" to 9.5 EEE pc version
Nov 26, 2009 | Twinhead DURABOOK N15RI Barebone
I cannot open my computer because of my password. We are in the mountains of Arkansas and cant get on line but i should be able to at least open it for the games. It says I need a usb flash drive or floppy...
When u powerup press F2 or "del" F1 key to enter in bios.
but if u have problem of bios password followbelow procedure
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user password
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Aug 07, 2009 | Gateway M-1628 Notebook
Hard drive locked
First check in bios that your harddisk is detected or not?
You can ente rin bios with following method:
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
Jun 15, 2009 | ASUS M5N PC Notebook
Locked out
you can try locating the cmos battery and disconnecting it for 10 seconds then re-connecting it. this basically erases the settings on the bios as well as resets the system time. but it might not take out the password.
Apr 22, 2008 | Computers & Internet
Shopnbc DURABOOK U12C 12.1IN CONVERTBLE NOTEBOOK Logo
77 people viewed this question
Top Shopnbc Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Shopnbc Audio Player and Recorder Expert? Answer questions, earn points and help others
