Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
Faucet spout is too loose - Blanco Classic Single Handle Faucet with Pull-Out Spray ....
How do I fix leaky faucet?
Sounds like your water supply lines under sink where they connect to faucet unit are loose oo they didn't apply plumbers putty under the faucet unit it self
Nov 21, 2014 | Plumbing
Moen cathedral keeps coming loose and it base moves when you rotate the spout from sink to sink.
tighten the lock down nut under the sink , also,, unscrew the cap (at the base of the spout,, and Lube the O ring ( with either plummer grease if you have it, or if not with vasoline) this should cure your problem
May 04, 2011 | Moen Monticello Single-Handle Kitchen...
American Standard Jasmine 3821.834 leaking where spout enters base
How long have you had this? is everythign tight? check underneath the sink to ensure all connections are tight. The spout may have came loose, and it may not be able to be fixed, may need to be replaced.
Mar 29, 2011 | American Standard Jasmine 3821.834.295...
I am leaking at the base of the spout. if you put any kind of pressure on it to move it from side to side it leaks. this is a two handle kitchen meon faucet
At the base of the spout it should have an o ring on the spout does it have a nut or cap on the spout that will unscrew to gain access to it. turn water off first.
If it is loose you could try tighting it , but most of the time it would be th e or ring.
May 15, 2010 | Moen 7910 Chateau Two-Handle Kitchen...
How do I tighten a Delta kitchen faucet that has become loose?
If it is faucet body on sink loose under sink there should be screws and a plate or washers holding it sink. Tighten them up.
Some have a bolt or nut in the middle requiring a socket to tighten.
If the spout is loose remove handle and it has a plastic ring on top to tighten spout up.
Feb 13, 2010 | Delta Faucet Plumbing
Is their a way to tighten the spout on a Grohe Atrio kitchen/bar faucet? It seems a little loose, but is not leaking
try to tighten collar at base of spout if that dosent work o-ring could be bad
Aug 20, 2009 | Plumbing
Grohe ladylux faucet loose on counter.
Here is the manufactures web where you may request the information you desire concerning your faucet.
http://www.groheamerica.com/s/25_4060/page/modules/iframe/index.php?if_url=http://12.130.64.173/litrequest2.htm
Dec 10, 2008 | Grohe Plumbing
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
