Question about Big Gun Polaris RZR 170 EVO Sport Utility Series Exhausts
Polaris razr 170 4 stroke it will turn over but it will not crank ,checked the filter and the carb, but for some reason it wont crank up except when you spray carb start in the carb.
Polaris won't start will back fire
air leak in the intake somewhere. clean carbs too. if its 2 stroke with a piston port check your crank seals
Apr 20, 2015 | ATVs
95 polaris xplorer wont stay runnin
There are many reasons your car may not start. Check the fuel supply to your engine. If that's okay, check the wiring to and from the starter for a loose connection. If there is a "clicking" noise when you try to start it, you may need a new starter.
FGTech Galletto 2-Master EOBD2 V51 BDM-TriCore-OBD
Dec 17, 2012 | Polaris ATV
1996 Polaris Sportsman 400 Will Not Start
If your atv has been sitting this long, the carb is probably stopped up internally... take the carb to a qualified professional and have it cleaned and set...(take a few pictures so you know where all the hoses re-attach)
ALL it takes for an engine to run is:
1. A timed spark
2. Adequate compression
3. Proper fuel/air ratio delivered
Aug 12, 2017 | Polaris ATV
Gasoline in oil motor
needle valve in carb is stuckk allowing gas to free flow into engine rebuild kit for carb is around 35.00 drain everything do not try cranking until all old oil is out and replaced. Change filters and check compression i just had same problem>
Apr 10, 2012 | Polaris ATV
2004 Polaris Sportsman 400 - Engine cuts out when climbing hills or when pulling a heavy load? The engine wont shut down on me but it looses its power and sputters until it gets to level ground. I had a...
well there are a couple of things that can cause this to happen. first check your oil and coolent. odd sounding i know but this can cause it. second check and make sure your cluchs are working correctly. next if all that fails then i would check the air intake for blockages and then service the carb.
reply if you need more help :)
Aug 03, 2010 | Polaris ATV
250 Polaris Trailblazer wont start- new spark new filiter help
Did u choke it ? -stroke are very cold blooded Mine(2003) needs a choke after sitting 1/2 hr at 70 degrees.
Mar 31, 2010 | Polaris ATV
97 Polaris Xplorer 500 4X4 rev problem
REPLACE THE CAMSHAFT !!!,,, HAVE A LOOK AT CAMSHAFT , EXHAUST LOBE IS PROBABLY WORE RIGHT OFF....
Nov 03, 2009 | Polaris ATV
Polaris Xpress 300. Won't start, backfires through carb sometimes
Sounds like maybe the needle and seat in the carb letting gas through.
Jun 28, 2009 | Polaris ATV
WONT START
Not so many reasons she won't start. 4-Strokes are Simple!
Here they are:
Motor:
Fuel Tank-> Fuel Line-> Fuel Filter-> Carb-> Intake (Valve)-> Piston-> Exhaust (Valve)-> Muffler
Carb (Old Style):
Fuel Side:
Fuel Bowl-> Float-> Needle Seat-> Fuel Ports (Venturi)
Air Side:
Air Filter-> Carb Air Intake-> Butterflies (2)
(Clean 'em ALL!)
Hardware (Motor):
Rotor (Magnets)-> Magneto (Ignition Coil)-> Spark Plug Wire-> Spark Plug-> Cylinder Head (Spark Plug Ground)
Ignition:
Kill Switches (Seat, Clutch, etc.)-> Spark Plug/Ignition Coil-> Ground
Key Ignition-> Battery->Starter/Generator
If one of those fail.......= Non-Starting 4-Stroke!
Fixes-
Fuel:
You are either getting too much, or too little. Too much = Carb.
Too little = Carb. Therefore, tear down the Carb (COMPLETELY-Careful!) and clean it up.
Electrical:
Grounding out the System (Kill Switches)
Battery-> Ignition-> Starter.
Magneto->Plug Wire->Plug (Check 'em all!)
May 28, 2009 | Mtd Garden
Big Gun Polaris RZR 170 EVO Sport Utility Series Exhausts Logo
108 people viewed this question
Top Big Gun Tools & Hardware - Others Experts
Are you a Big Gun Tool and Hardware - Other Expert? Answer questions, earn points and help others
