Question about Oki Brand Oki C610n Laser Printer Network-Ready
Oki c610 laser printer problems
Print faded at edge
My oki data C5200 in printing a faded picture along the right side of the page only. I have cleaned the print heads and checked the levels in the cartridges. Everything seems to be fine. Can you help?
> OKI C5200n laser printer
Take the toner-cartridge out, and gently tilt it left-and-right
to redistribute the remaining toner in the cartridge.
Reinstall it.
Oct 13, 2010 | OKI C5200n Laser Printer
Printing of blank lines...
Since you didn't state how old the printer is or how many pages it has on it, my best bet that the drums are going bad, if you provide me with further details i can help you more
Mar 25, 2010 | OKI C5100n Laser Printer
I have Oki B4350 printer. The print on both edges
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored .
Jun 03, 2009 | OKI B4350 Laser Printer
OkiC5200 has an inch wide faded print line down the left side
It might be a dirty led assembly. The leds hang down from the top when it is opened.
May 03, 2009 | OKI C5200n Laser Printer
Incorect line of colour from one edge to the other
I am presuming the rest of the page prints the correct colour and this is an area in the direction of feed that is missing yellow. Try swapping the yellow and magenta drum positions and then the green text should come out a very dark blue colour. if it does then the fault is with the YELLOW drum, if there is still a noticeable Cyan stripe still then the fault will be with the LED head or engine control board.
Apr 21, 2009 | OKI C5100n Laser Printer
Problem printing black
Have u tried to clean the leed´s?, the thing hanging over the toner, clean with a piece of cotton.
Good Luck
Sep 04, 2008 | OKI C5100n Laser Printer
OKI 5600 - Can you do a 'clean'?
Here's the 'secret' sevice manual: http://www.feedroller.com/Store/Service%20Manual/50_53_5600.PDF
I would also (very carefully) check for torn paper around the rollers of the imaging drum that might be rubbing the area.
Nov 09, 2007 | OKI C5200n Laser Printer
Oki Brand Oki C610n Laser Printer Network-Ready Logo
66 people viewed this question
Top Oki Brand Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Oki Brand Office Equipment and Supply Expert? Answer questions, earn points and help others
