Question about Arris Computers & Internet
I have an Arris router installed by Comcast-home 71D2 but don't have the password
I don't have the password. H.showalter70@yahoo.com
oldnovii
  • 667 Answers
SOURCE: how is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
Posted on Jul 22, 2008
  • 31 Answers
SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
Posted on Apr 09, 2009
  • 31 Answers
SOURCE: i have an arris tm602gct and cannot connect thru my netgear
Can you connect if you are directly wired into the router?
You may want to try using a ball point pen and pressing the reset button on the back of the arris. Let it reboot and try again.
Some netgear routers come with the wireless disabled out of the box, so you need to be hard wired when you run the CD or if you try to connect through your browser 192.168.1.1
  • 29 Answers
SOURCE: Unable to connect VPN using Arris Modem & Comcast Router
hi, mate check firewall settings of your modem/router. Then contact your IT administrator and he should be able to make changes to configurations for you. In most cases if server classify's your connection as unsafe it rejects it.
Posted on Jul 18, 2009
SOURCE: Problem with my Arris Comcast cable modem.
I just had a tech out yesterday regarding this problem on a TM402 - restarts under high network saturation (big uploads or downloads). According to the tech, this is a know issue. Comcast upgraded their network to support multiple carriers (called channel bonding) dynamically. Due to this upgrade, when your modem is demanding high bandwidth for large downloads, essentially, it requests an additional carrier (or channel)...when that request is initiated, the modem's hardware (and firmware) can't connect to more than one channel at a time, therefore, it "gets confused" and restarts itself to attempt to fix the problem. I upgraded to the TM602, and the problem is still there. This is because the channel bonding feature requires a Docsis 3.0 capable modem. The Arris TM702 is the first in the Arris line to offer docsis 3.0. I called Comcast and they are upgrading me to the Arris TM702 (which is a 50M down/10M up service, btw) for an additional $30/month - well worth it for the stability which I require.
As far as Comcast saying that it's fine, call them back with the information I provided, and ask to get you to a tech who can better service your needs...unfortunately, the "tier 1" techs don't have a clue.
Posted on Dec 07, 2009
Where to find the password
http://arris.force.com/consumers/articles/General_FAQs/SBG6782-Admin-Login-Setup
if you have not changed the default password and user name !
it is listed on the web page on the above link
Go to wireless tab at top of screen and look up WPA Key or WEP key and make a note of what it is on 2.4 GHz frequencies as I think this will be dual band with 5 GHz as well but Ipad will run on 2.4 GHz only as it will be 802.11n as opposed to 802.11AC
Note if you changed the user name password or user name you will have to reset the router back to factory defaults but be aware everything defaults so ISP cable settings reset (would need ISP to tell you what they are and help set them back up)
(wireless settings change so you need ethernet cable directly into router to set up wireless)
Hopefully your still set up on the router on the default user name and password !
Jul 02, 2015 | Arris Surfboard Extreme Docsis 3.0...
How do I find my WIFI password ?
Depends on router. You can look at the router settings if you have a cable that you can connect to the router. Then you put in the router setup cd or you can use the IP address for the router. You should get a menu that comes up that you can browse through to find it and change it. If you have COMCAST and the ARRIS router, the password is on the label on the back of it. You can also reset the router and wipe the password out on some routers by pressing in the reset button that is on the unit.
Sep 28, 2014 | Computers & Internet
I need to find my password to my wifi internet
The Xfinity Arris 805 and 862 and CP3939 wifi info is on the bottom of the router on the white sticker. If the sticker is missing call Comcast 1-800-226-2278
Jan 22, 2014 | Comcast XFINITY
I got can't find my password key on my cpe25150 Motorola router and I'm trying to connect comcast arris using an iPad
Try looking for a label on the side of your cpe, you should find it there, it may be all numbers, or letters, or Combo, if you see letters in Caps or not, be sure you type it exact, it will be case Sensitive..
Mar 26, 2013 | Computers & Internet
We are currently running Comcast internet and phone through a Netgear Wireless-N 300 Router and an Arris TM502G Modem. Our phone service works fine, but the "Link" light isn't showing up for...
There's a reset button on the back of the modem. It'll power cycle it. That should work and if it doesn't make sure everything is connected and tightened.
Jul 29, 2011 | Arris Touchstone 450a (CM450) Modem
I am renting an ARRIS model TM722G/CT modem from Comcast and would like to buy a like product that is compatible with the current rental. Do you sell this product to consumers of Comcast or are you...
We don't sell anything, we are a helping site.
You need something like this
http://www.amazon.com/Motorola-SB6120-SURFboard-eXtreme-Broadband/dp/tech-data/B001UI2FPE/ref=de_a_smtd
Jun 10, 2011 | Computers & Internet
I need the wep security code for my sons dsi to download games on it from the internet. router name arris model # cm450a
When you did the initial setup for your router, you should have configured the wireless adapter in the router:
* set a SSID -- the "name" of the network
* set an encryption-level -- hint: use 'WPA' or 'WPA2'
* set a password for your network
It's that SSID/password that you need to enter on the DSI, to make a wireless connection to your router.
Apr 21, 2011 | Arris Touchstone 450a (CM450) Modem
Jul 17, 2009 | Computers & Internet
Wi-Fi isn't working
Mar 01, 2009 | Arris Touchstone 450a (CM450) Modem
Computers & Internet Logo
44 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
