Question about Michael Kors MK5616 Watches - Gold One Size One Size
How to set the small circles on my MK 5616 watch
How do I Replace the battery for my Michael kors mk-5758 watch
  • Remove back
  • Find battery in holder and identify type. Note mounting for reference during installation
  • Place watch and back in a plastic bag to prevent contamination while you obtain a replacement battery
  • Remove old battery
  • Install new battery
  • Check operation
  • Install back
  • Set time etc.
Aug 30, 2016 | Michael Kors Watches
Who I can set time on watch model 5616/3
Made a google search but couldn't find this "model" .
Maybe you could provide make of it? Might have luck... According to my eperience, there are rather few instruction manuals on watches on lne, but might have some luck looking for it.
Aug 02, 2015 | Watches
How to change the date number on MK watch
Try pulling the crown out part way, it may have intermediate stops for day/date setting, and turn CW for one setting and CCW for the other.
Mar 02, 2015 | Watches
How can i remove the back from a mk watch that has four screws
Tricky question here.
If the watch case is made of metal, you will have no problem finding a screwdriver in some electronics parts store.
But be careful!!, if your MK has got a policarbonate case you are in danger by doing it yourself.
May happen you damage the screws head , and then you have to buy a new (and really expensive) case for your beloved watch.
If this is your case, I'd rather took it to a Michael Kors watch shop to do the job. It can save you a lot of money.
Regards.
Michael Kors Watches MK
Jun 15, 2014 | Michael Kors Watches
I don't have an instruction manual for Zoo York
have a zoo york watch and I can't understand the directions
Aug 10, 2011 | Watches
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
Michael Kors MK5616 Watches - Gold One Size One Size Logo
74 people viewed this question
Top Michael Kors Watches Experts
Ansel Alberto
Ansel Alberto
ray gallant
Are you a Michael Kors Watch Expert? Answer questions, earn points and help others
