Question about Frigidaire ATF6700FS Front Load Washer
Model FAFW3577KW0 error E41 - Frigidaire ATF6700FS Front Load Washer
I have an error code E41 on my Frigidaire ATF7000eso front load washer. How do I test to find the bad part
Good Morning friend, that's a great question!
I see that your Frigidaire washer, ATF7000ES0, is displaying an error code of "E41" and you would like assistance in troubleshooting that code. An "E41" typically stands for your main control board thinks the door switch is open. This could be a possible problem with your door switch assembly or main control board. I would recommend performing a reset just in case there is a miscommunication within the board and you can do that by disconnecting power from your washer for roughly ten minutes. If you restore power and continue to see an "E41" I would look over the door switch to make sure it is not damaged. If any electrical components need to be replaced I would suggest having a professional technician out to properly disassemble your washer. This will help you to avoid any future issues. -Matt
Feb 21, 2015 | Frigidaire Washing Machines
Where is the main control panel located and how do I change it?
Hi Terry, for the most part, error code E41 does indicate a door lock mechanism failure; however, if you have already replaced that part, it is more than likely the control board. The control board is typically located right behind the control console. Before the control board l is replaced, be sure to confirm that your service technician has ordered the appropriate part. According to your post, it appears that you have model number ATF6000ES, which would require part number 134523106. Hope this information helps! Thanks for your question.
Jul 24, 2013 | Frigidaire ATF6000ES Front Load Washer
What is error code E41
Hello Scott - If you are receiving an error code E41, your loading door may be ajar. Double-check to ensure that it is closed. If it is secure, reset the power to your appliance for about 30 seconds. You can do this by unplugging the unit or flipping your circuit breaker into the off position. If the error persists, it could either be the door switch assembly or your unit's main control board. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Jun 10, 2013 | Electrolux Ewf1090 Front Loader Belt Part...
Fridgidaire upright washer E41
Hello Marcee Peterson - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Error code e41
Hello phrainer3 - Error code E41 indicates that the main control board thinks the door switch is open. Contact a professional to check the continuity between the pins in the plug and door strike. The unit either has a defective door switch assembly or main control board.
Oct 01, 2012 | Frigidaire Affinity ATF7000E Front Load...
I own a husky te449 2011 model and the clock keeps giving me ERROR E41 can anyone help me
Possible there is error on the clock processor, fault on the connector or fault in the board, could be a crack or damage.
You will need to remove the panel to have a view from where we can confirm the case. make sure all the connectors are tight
Nov 07, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
Dr is flashing. The error code is E41. How do I correct the error code. Door is closed. Started flashing in the middle of cycle.
Hello, welcome to FixYa. I understand you have a Frigidaire washer with an error code E41, correct ? Can you reply and include the complete model number ? This will let me speak specifically about your washer instead of generalizing...which can be fine, but specifics are always better. I'll watch for your reply and go from there. Thank you. Regards, Macmarkus :)
Sep 17, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity washer (LAFW3511KW0) with an E41 error. I have unplugged to reset (no change), checked the stricker (fine), removed outer seal and disconnected and reattached (I also received an E41...
Install the door lock/switch assembly with the door switch harness disconnected but "jumped". Jump a wire between the wire harness terminals and if the error code (E41) stops appearing when the machine is started, the door lock/switch assembly is indeed faulty and needs to be replaced.
Check the continuity of the door switch harness connecting the switch and terminal J2 of of the control board if the error code (E41) still appears every time the machine is started after putting a jumper wire between the door switch harness terminals.
Make sure the connectors are clean and snugly connected to both. Replace the wire harness if you are skeptical about its condition. Disconnecting the door switch wire harness (J2) from the control board and putting a jumper wire between the leads of terminal J2 on the control board will directly confirm the condition of the wire harness and the board itself. The wire harness is the problem and must be replaced if the error code E41 stops appearing. On the other hand, consider replacing the control board if the error code still flashes even when the leads of terminal J2 on the board is shorted ("jumped").
Aug 21, 2011 | Frigidaire Affinity ATF7000E Front Load...
Cm 1929 error code e41
i there i have a samsung cm1929 microwave and it coming up with the code e41 please help thanks mike
Nov 08, 2010 | Samsung MW1080STA Microwave Oven
Open Questions:
See all Frigidaire ATF6700FS Front Load Washer Questions
Frigidaire ATF6700FS Front Load Washer Logo
22 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
