Question about Baumatic B180 Electric Single Oven
What do I do now that the temperature markers have been scrubbed off??
Thanks to some over zealous tenants with a scrubber I now have a Baumatic 180 SS that has next to no display markers on the fascia. I can't tell what temperature the oven should be set at or what programme to set it on... I have to guess!! Does anyone have a photo of where the markers should go as the handbook detail is so small I can't work it out! Seons
  • Seonaid Dobie Jul 25, 2007
    Thnaks for the info. Went to the site and got what I needed. Hopefully my next tenants won't be so domesticated!
  • 51 Answers
Go to www.baumatic.co.uk then go to their online catalogue. Find your oven model & download the user manual. You will find 2 very clear pictures of the facia. Regards
Posted on Jul 25, 2007
SOURCE:
My Baumatic BS65MS oven is cooking too hot, it burns everything. I have turned down the temperature, this doesn't help. What would be the problem?
You may have a stuck thermostat and that should be replaced because he's probably telling the other keep eating even though the temperature the temperature would be correct
think your new oven is too hot or too hot or too cold, you can adjust the temperature yourself to meet your specific cooking preference. You can also adjust your thermostat if your oven is not new, since thermostats may "drift" from the factory setting over time. See the "Adjust the Oven Thermostat"
Mar 18, 2018 | Baumatic Ovens
I'm a landlord and my tenant's oven will not heat up to the proper temperature intermittently. I had a guy come out and test the oven and it works fine, yet my tenant is still complaining the oven is not...
Absolutely. That is the first thing I would think that would cause such a fluctuation of temperatures. BUT if it is a gas oven (WITH A PILOT FLAME) then FIRST consider the thermocouple needing to be changed. If the thermocouple keeps faulting it will shut off gas sporadically and keep the gas off until it resets temporarily on its own.
Mar 13, 2010 | Ovens
I have a baumatic bc3510ss double oven. everything works fine except the large oven. you can turn on the grill or oven but when you turn on the temperature the rcb blows on the fuse box.
Tthere are a couple of possibilities for your prob, the thermostat, or the oven element is faulty.
Disconnect the oven element, and try it again, if it does not trip, replace the element, if it still trips, replace the stat.
Please rate my solution.
Thanks.
Nov 01, 2009 | Baumatic Ovens
Baumatic built in oven (B600) product manual
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
Dec 07, 2008 | Baumatic Ovens
New World E70DOA - Oven/Grill Temperature
Steve, I have a PDF of the manual. send me an email to [email protected] and I will reply with document attached.. We recentley moved house and were in the same situation. We contacted Newworld who sent us a paper copy which I have scanned to PDF.
Dave
Apr 27, 2008 | New World E70DOa Electric Double Oven
Baumatic b180 oven
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories. I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe. In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link: http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B Hope that helps! ;)
Aug 05, 2007 | Baumatic B180SS And B60SS (Bundle)...
Baumatic B180 Electric Single Oven Logo
292 people viewed this question
Top Baumatic Ovens Experts
Marvin
Marvin
Dennis Boxerman
Lawrence Oravetz
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
