Question about Sharp Notevision PG-C45X Multimedia Projector
Sharp PG-C45X - yellow scorch on internal lens
After a catastrophic bulb failure - it audible popped, and there were glass fragments inside the bulb housing, when I replaced the bulb, I have a yellow smudge on the projection surface.
I've removed the bulb, and examined the first prismatic lens (plastic) just past the bulb, and it appears ok - and have cleaned all the lenses I can reach - but the yellow smudge is still present.
My IT guy opened the case, and there is a second plastic prismatic lens, that appears to have a brownish goo seeping out from between the panels. Is this a replaceable part? Or is the projector trashed?
  • 6 Answers
SOURCE: Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Posted on Jul 10, 2008
  • 2237 Answers
SOURCE: Hi guys! Have a Sharp PG-A10S projector problem.
go into the menu and reset to factory default settings. if that does not help, you have a bad polerizer (light color filter) on one of the lcd panels. sharp will sell the individual parts if you want to fix it yourself. if you want them to do it, they'll replace the entire optical engine and charge you a fortune.
Posted on Sep 02, 2009
  • 3 Answers
SOURCE: Sharp XGP25X Projector has large blue smudge on Screen
This is one of two things. Most likely there is a piece of dust or other obstruction right on top of the blue panel. I'm guessing that your smudge is in the lower center of the screen - that is where these usually occur. The other possibility is that the blue LCD panel is starting to deteriorate and the components separating. This is extremely expensive to repair and Sharp will end up giving you an estimate that approaches the replacement cost for a comparable new projector.
Posted on Sep 10, 2009
  • 75 Answers
SOURCE: reset password on sharp PG-C45X projector
I am not sure what the sequence is but sometimes you can hold a couple of buttons to reset this. The problem is that sharp does not like to say what the procedure is and that you will need to find a local dealer to help you with this. You may be able to do this over the phone or will need to drop it off.
Posted on Jun 05, 2010
  • 23 Answers
SOURCE: I just got a used
your bulb is going bad, replace it and the problem will be resolved.
Posted on Jul 05, 2011
Rest light imer on sharp pg c45x
Turn on projector, press and hold the input, enter and undo buttons on
the projector then while still holding those three press the on button. Make sure you do this before the timer goes to 0% or it wont turn on again.
Apr 21, 2011 | Sharp Notevision PG-C45X Multimedia...
Sharp XG-C50X Notevision. Doesn't get past "warming up"
it seems that the powersupply is failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Nov 21, 2009 | Sharp (BQCXGC50X1) Projector Lamp for...
Does anyone have a diagram describing the location of the fly eye lens in a Sharp XGC 50 projector?
Have a nice day!
Lampdeng Limited
Oct 03, 2009 | Sharp (BQCXGC50X1) Projector Lamp for...
PG-C45X projector wont power on
To solve this problem, simultaneously press the "Input", "Enter", and "Undo" buttons. While holding these buttons, press "On". When the project turns on, you should see "LAMP 100%". This indicates that you have successfully reset the lamp life timer.
Nov 17, 2008 | Sharp (BQCXGC50X1) Projector Lamp for...
Sharp notevision PG-C45X will not turn on
possible blown lamp I think that is what the flashing red light means check manual
Oct 03, 2008 | Sharp Notevision PG-C45X Multimedia...
Connecting a dell
first you must switch computer first then lcd projector second.
second:if nothing happen please do the following:-
press control+f4 or control+f6 or control+f7.
best regards.
Mar 05, 2008 | Sharp PG-C45X Notevision 2500 Lumens XGA...
Sharp Notevision PG-C45X Multimedia Projector Logo
105 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
