Question about Select Products Stanley 5 Beam Laser Level Sp5 Sp5 Great Gift
Stanley SP5 5 beam laser level, one of the lasers not working. How do I fix this?
Geo fennel fl200a-n calibration
ck to see that piviot bearing does not have and dust or junk in it and moves very easy , i use mine for drywall and i have to clean out piviot all the time to get proper level from it
Jul 06, 2014 | Stanley 77 156 RL100 Manual Leveling Dual...
Where do I buy a Stanley RL250 Fat Max Laser Level battery charger
I know it's 3 years old this question but I had the same problem. Good thing is the makita battery willl fit. I just got one from ebay works great
1500mAh 7.2V BATTERY FOR MAKITA 7000 7002 7033 192695-4 632002-4 Cordless Drill
Mar 02, 2013 | Stanley Proto STANLEY IntelliDual Box Beam...
Ideal #35-207 how to get it to work
Here is a page capture from the manual of the operation of your laser level/ Hope this helps. (highligt and copy to a viewing program like MSPaint in order to zoom in)
Dec 13, 2011 | Select Products Stanley 5 Beam Laser Level...
HI Can i use the xp180 on the floor to hang curtain rails
It is a good laser, but it is self leveling so you will have trouble setting it on the floor and be able to title it. It will probably go into error mode and the laser will flash telling you that it isn't level.
Suggest a step ladder that is about the right height.
Jul 16, 2011 | Stanley Proto Stanley xp180 Cross Line...
Vertical laser is no longer working.
Had the same problem. Actually had vertical beam and one horizontal beam not working. I put the laser in the freezer for about 30 minutes, took it out and all the beams work. Prior to that I cleaned all the battery contacts and of course installed fresh batteries all to no avail. I have no idea freezing it worked but it did. Of course freezing it would cause condensation to form on the inside of the instrument but why that would make the laser work is not known. I hope it works for you.
Jim from Fredonia.
Mar 08, 2011 | Select Products Stanley 5 Beam Laser Level...
No laser beam how to fix
I would check the batterys first and if they are good, generally there is no way for an end user to fix a laser. I have talked to DeWalt in the past about this and been advised not to open it up. you can try to reset the laser and see if it reboots, sometimes they are so far out they won't turn the laser on.
Jan 31, 2011 | Stanley 77 156 RL100 Manual Leveling Dual...
Just wondering if the stanley SP5 5 beam laser level can be used oudoors.
Yes but i don't recommend it the light has to be perfect, in order to see the beam.
Jan 28, 2011 | Stanley 5beam Laser Level
How do I calibrate my stanley laser level
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
Jun 17, 2010 | Stanley 77 156 RL100 Manual Leveling Dual...
Select Products Stanley 5 Beam Laser Level Sp5 Sp5 Great Gift Logo
47 people viewed this question
Top Select Products Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Select Products Measuring Tool and Sensor Expert? Answer questions, earn points and help others
