Question about Marantz SR-5000
How do I run a speaker tone test on my Marantz NR1403 ?
2 Suggested Answers
bobhifi
  • 635 Answers
SOURCE: I have had my Marantz
First of all if you have not made any connection changes in the system prior to loosing the sound try these steps.
Go into the system menu and in speaker configuration see if somebody has given the rear ( surround ) speakers as none. If not just exchange the front and back speakers to confirm if its a speaker failure . If not you will need professional help to fix a damaged surround amplifier.
Posted on Mar 08, 2011
How do I connect the audio from a Panasonic to p50-s1 to a marantz nr1403 so that I get surround sound audio?
The Audyssey setup does not use any audio from the TV. Audyssey is started automatically when you plug in the calibration microphone. Once you start the setup, it will output a calibration tone to each speaker. (Read the Audyssey setup instructions.) There is 1 digital audio optical input on the back of the NR1403. You will need a optical digital cable for the connection. Once connected, you'll need to use the input setup menus to select that digital sound input to go with the video input you are watching. Check page 15 of the manual.
Jan 01, 2015 | Marantz Audio Players & Recorders
Marantz NR1403 standby mode only
Connect all speakers . Does it start?
If not , you have at least one audio output amplifier failure.
Seek out a Marantz dealer to help you get a tech
Jan 31, 2014 | Marantz NR1403 Slim-Line Dolby TrueHD AV...
I have marantz Av surround receiver model SR301 I have tried a lot but I am having sound from only 2 speaker when I put in setero mode but when I put in surround no sound from any speakers I checked all...
First off you will need to do a little bit of trouble shooting. Is the source (dvd, Blu-ray, cable box, etc...) plugged into the receiver with the standard red and white RCA cord or by an optical (toslink-fiber optic) or digital RCA (orange color code). If you are connected with a standard RCA cord then that it your problem and you need buy digital cord that both the source device and the receiver can accept (toslink - http://www.we-supply.com/browse.cfm/optical:-audio/2,779.html or Digital RCA). If the connection is now correct then you need to make your receiver do a "test-tone" to insure that a signal can be sent to every speaker (this is an internal test that just checks the speaker connections). If the tone tone operates correctly then you know the amplifier is functioning. If both of the mentioned things are now done and still not surround output then you need to check the internal menus on your source device and make sure that it does not require you to manual change a setting in the audio menu to make it work (i.e. change from 2-ch 44KHz to 5.1 or 7.1 or Dolby Digital or AC3 or some other surround sound protocol.)
Austin
www.we-supply.com
Aug 08, 2013 | Audio Players & Recorders
Marantz NR 1403 & Preamp - Volume cannot be controlled by receiver
The newer surround sound recievers will not work no matter what you try with them the way you have it hool up, they are not design to be useing a turn table on them that has a mgnetic cartridge ,Evan if you buy a phono preamp for it, you are just wasteing your time end money, I was a electronic tech for over 40 years ,Before i retired this summer, End no lots of people who tried to do the same thing your trying to do ,End It would not work,
Nov 26, 2012 | Marantz Audio Players & Recorders
HI, I have Receiver Marrantz SR- 5005, the center chanel does not work, please tell me what happened and solution to fix the problem. Thanks
Get the manual and open it up to the part where speakers are defined, then test it/them with tones. Try swapping a different speaker into the center if the current center channel speaker still doesn't work.
Web search "Marantz SR-5005 manual" (note the spelling)
Aug 07, 2011 | Audio Players & Recorders
My sr 18 has no audio output,on all speakers,but video is good.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR-18EX-Receivers-manual/id/511ci766/t/2/
Headphones connected?
Disregarding specific sources, how does it do with test tones?
Jul 09, 2011 | Marantz SR-18EX Receiver
Hey, I purchased Marantz set: audio SR4400 and dvd DV4400, but I have no idea how to connect the two together. I want to listen to music and watch films on dvd with the sound coming from the speakers, but...
Yes, read the manuals.
It IS complex and NOT for guessing.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR4400-Receivers-manual/id/511dj795/t/2/
http://www.retrevo.com/support/Marantz-DV4400-DVD-Players-manual/id/511ag817/t/2/
Did you even get the SR4400 and speakers to the point that it runs by itself (test tones, FM)?
Master that part, then attach peripherals.
Some basics to keep in mind:
INs connect to OUTs.
Compatible connectors fit without modification.
Never test with MAXIMUM volume. If you can't hear something at medium volume it ain't there.
Regarding the DV4400: I'd advise you to run it's Component Video directly to your TV and its coaxial digital audio to the receiver so each medium is handled by the intended specialized electronics first. Run the DVD analog audio to the TV for watching news using TV speakers and without the receiver turned on.
>>>> * A word on coaxial vs spdif (optical) audio cabling - I always use coaxial if I have the choice because it is A) cheap RCA cable available anywhere in any reasonable length you want to run; B) can be extended and SHARED with other components if you have limited jacks available. You just have to be careful to make sure only one digital source at a time is turned on while using the other; C) RCA cable is impervious to problems arising from tight bends; optical is physically delicate and won
Mar 12, 2011 | Marantz Electronics - Others
I have had my Marantz Sr5000 for some time now and I just noticed the rear speakers have stopped working. Everything else seems to be working fine. When I run the test tone I get a tone from everything but...
Mar 08, 2011 | Marantz SR-5000
NO RESPONSE FROM YAMAHA YST-SW305/205
Hi Ron,
It sounds like the sub is not auto turning on, or has no audio output, and or the sub driver itself has failed. Do you have a multimeter, and we can diagnose the unit? :)
regards
Graeme
Mar 02, 2008 | Audio Players & Recorders
Marantz SR-5000 Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
