Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator doesn't turn
Agitator seems not to catch and doesn't churn clothes well
  • andrea_ault Jan 30, 2009
    This was a simple repair to make with very inexpensive parts. I am happy to pay a skilled repair person when necessary, but the info I received confirmed my hunch that this was not a complicated fix, and it saved me money for not a lot of work!
  • 130 Answers
Take the top off the agitator, pull the cover out, there should be a bolt to unscrew, after this os off take off the top and you will probably need some agitator dogs.
Posted on Jan 26, 2009
HOW DO YOU RELACE THE DOGS?
Replacing the dogs in most auger/agitators is kind of tricky, do to the fact that they heat seal most of the components together. Personally I have both failed and suceeded attemping this. As well it is quite hard to explain how to do without actually being there, it is fairly straight forward, Basically the dogs are inside the agitator so that when the agitation begins the back and forth action, it doesn't simply spin the agitator around and around, free spinning, or not at all, so the dogs catche and releases the splines inside the body of the agitator so your clothes are "agitated" to the point of getting clean. With that said, the most efficient way of dealing with this problem is by getting the agitator dog assembly, I looked up your model number and I believe that the part number you're seeking is 285811 agitator cam kit. Please contact if you have any questions.
Jul 09, 2012 | Whirlpool LSR5132PQ Top Load Washer
The agitator doesn't seem to turn.
If only your experiencing a agitate problem and your washer spins ok the most likely problem is going to be with the little thing that fit inside of the upper barrel of the agitator called the dogs that are worn out and not catching.
This tip i wrote is about replacing the agaitator dogs.
http://www1.fixya.com/support/r10294924-top_part_agatator_isnt_turning_top_load
GENE
Sep 28, 2011 | Whirlpool Washing Machines
The agitatae doesn't seem to be cycling the
The agitator is made in two parts. Upper and lower. The bottom part does the actual agitating.
The upper part is supposed to be loosely fitted. It just screws down the clothes to contact
the bottom agitator slowly.
The top part turns one way, and slips the other way. By the action of what is called "Dogs" inside
the top part. These dogs are probably worn and need to be replaced
Take the top off the agitator and there is one bolt in the middle of the agitator. use a long extension
to reach the bolt and remove it.
Pull off top agitator (keep it straight up so you don't lose the dogs_
Go to local Appliance store and ask for Agitator Dogs.
Replace Dogs exactly as they came out
When you re-assemble the top it will be loose. This is normal.
Good Luck!
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
The agitater is not solid and clothes catch under the arms on the bottom and tangle and have even ripped. What can be done about to stop this? It seems like a design flaw to me.
It is not the best of designs.
Sometimes, clothes will get stuck at the bottom when the agitator dogs are worn out. Check to see if the upper part of the agitator is working during the wash cycle. If it isn't, the clothes stay at the bottom and just move horizontally, not from the bottom to the top. The clothes then get stuck in the gap between the lower agitator vaens and the bottom of the agitator. This is a very easy repair, you need only a socket wrench set (SAE) with an extension.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/2744
You can also buy the dogs (pawls) by themselves in a pack of four for about $5.
When I first saw this agitator set-up, I asked myself, 'What were they thinking of?'.
Good luck.
Mar 09, 2011 | Estate TAWS800JQ Top Load Washer
Whirlpool washer does not agitate/wash but the spin cycle seems to work. I've found that the bottom section of the agitator blades are turning but the top section does not turn. I can also turn the top...
The problem that your washing machine is not agitating, you will need to check certain things.
Please check the timer to see if it is in good working order or not. Next you will need to check the motor and the motor switch. On some of the newer washers the door switch also controls the motor.
If the motor starts running after the washer has filled to the selected level, but the agitator doesn’t move, you will need to check the following parts.
The agitator dogs. They are located inside of the agitator clothes mover. You will need to remove them and check to see if they are in need of been replace.
The clothes mover. This part is the top part of the dual action agitator. Its job is to move the clothes from the top of the spin drum to the bottom part of the agitator.
You will also have to check the inside of the clothes mover to make sure that the gear like cuts are not worn out.
However another problem could be a broken motor coupler.
Thank you for contacting Fixya.com
Aug 09, 2009 | Whirlpool Washing Machines
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
Top agitator doesnot work
Your agitator dogs are worn out. They are 4 small pieces in the agitator that act as one way clutches. They allow the top section to turn one way but catch the other way. Pretty simple fix.
If you will post the complete model number I will find the part numbers for you and try to provide instructions on replacing them.
Nov 26, 2007 | Whirlpool LSB6200PQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
