Question about RCA Televison & Video
Dvd problem rca 22lb45rqd - RCA Televison & Video
How to hook up an old RCA 14 inch tv to DVD
Easy. All you have to do is to make sure that the DVD player is old the older types that have RCA connectors at the back of the DVD. Latest DVD may have RCA connections but I am not sure if it can send digital signal directly to the analog TV. Try this and see what happens. if your TV is old and does not have Component Video (Red/Green/Blue) RCA sockets (input) but has standard Pal/NTSC sockets (Yellow/Red/Black) hook up the yellow, red and black plugs into a DVD (out) RCA sockets of same colour, then hook up the other end of the cable in the (in) RCA sockets at the rear of the TV.
If it works, then all is well. If it doesn't work, then you have to hook up the cable from the DVD to the (input) RCA sockets of a Set Top Box, so that the Set Top Box will convert the signals for the analog TV. Just pay attention to the inputs and outputs at the rear of them.
On your DVD - plug the RCA cable to the (OUTPUT) RCA sockets. On the Set Top Box - plug the connectors in the (IN) RCA sockets and then use another cable connected to the OUT RCA's of the Set Top Box, then connect the other connectors to the (IN) of the TV RCA sockets. Hopefully you get the picture on what I mean.
Sep 01, 2014 | Televison & Video
I have rca tru flat tv w/built in dvd and i have universal remote I cant get the dvd set on the remote also I cant get dvd to rewind or fast forward
Hello
It will be very difficult to get all functions of the RCA device, synchronise with a universal remote control. Just find a code, whic has maximum finctionality. That is all we can do. Just try an other code for RCA TV to universal remote. I hereby send some codes to check. OK
TV: 1144 DVD: 3423, TV: 1146 DVD: 3424
TV:045 DVD:091
Jan 21, 2012 | RCA 20F610TD TruFlat TV/DVD
How to connect dvd player to tv
In order of best to worst quality, and depending on which connectors both have.
1. Hdmi ( Video and Sound in one cable )
2. RGB also known as color stream (Red,Blue, and Green RCA ) Sound Seperate ( Red and White RCA )
3. Composite ( Yellow RCA ) Sound Seperate ( Red and White RCA ) sometimes mono (single sound RCA)
4. COAX (cable) which most DVD players don't have.
All RCA connections on devices should be center color coded And grouped by connection Video 1 Video 2 ect.
Mar 16, 2010 | Philips Magnavox DVD Player MWD200F
RCA D52W136D 52 in. TV/DVD Combo dvd does not play
did you try to get a dvd cleaner to clean out your dvd player.
Feb 13, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Consolidating remote with dvd player
No can do!!
http://www.rca.newremotecontrol.com/catalog_item.php?catnum=260605
Read the above link!This RCA remote is only good for RCA TV,DVD player and VCR.
solutiondoct
Nov 12, 2008 | Sony DVP-NS315 DVD Player
I NEED REMOTE CODES FOR THIS DVD RCA DRC200N
I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
Oct 17, 2007 | RCA DRC200N
DVD SETUP
hi try these Code For Model RCR450 (the closest i found) Code 1000/3160/2000 for RCA TV/VCR/DVD Code 1000/3408/2000 for RCA TV/VCR/DVD http://www.rca.com/customerservice good luck windman
Dec 19, 2005 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
