Question about Philips 60PP9352 60" Rear Projection Television
Chirping noise My tv was working fine and then I turned it off. My husband came home from work,(about an hour later) turned on the tv, and there was no sound, no picture, just a chirping noise coming from inside. We tried a hard reset,(unplugging for 4 hours) that didn't work. Then we left it unplugged overnight, tried turning it on the next morning and just got the same thing..Any clue what could've happened and maybe an estimate of the repair cost??Or can we fix it ourself? The tv is approx. 5 years old. Thanks for any info!
    Scholar:
  • 150 Answers
Sounds like something may be shorted out inside keeping the power supply loaded enough it wont start, dont recommend trying to fix unless you know EXACTLY what you are doing, there are some high voltages inside, I wold Call a TV tech out to repair, Just FYI, these sets from Phillips/MAG usually have CRT fluid getting cloudy causing discoloration/fog to pix around this age and older, between both repairs, some sets start around $1000, just an idea.
Posted on Jul 18, 2007
SOURCE:
Hazard lights work, individual signals do not
Could be bad flasher unit. Hazards use separate flasher.
Mar 13, 2015 | 1988 Toyota Corolla 4 Door
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
TV NOT WORKING
TURNED TV ON AGAIN 2 DAYS LATER AND IT WORKED.
Jan 18, 2009 | Sony Televison & Video
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
No power just a chirping noise.
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
Oct 21, 2007 | Philips 60PP9352 60" Rear Projection...
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
