Question about Leviton Toggle Touch Dimmer - TGI06-1LB - N/A
Install lutron ct600p - Leviton Toggle Touch Dimmer - TGI06-1LB - N/A
Switch and dimmer work opposite each other
Refer this issue directly to Lutron. They could have an ineresting explanation!
Jan 27, 2014 | Lutron Toggler Single Pole 600 Watt Preset...
How to install a 3 way lutron MACL-350 SWITCH
General info.. Power to gold screw. Fixture to silver screw. Black screw to black screw on each switch.
Dec 02, 2013 | Lutron #D-600PH-DK 600W SP Push Rotating...
Can the Lutron MIR-600 Dimmer switch be synced with a comcast remote? And if so how?
No. A remote must be able to learn IR codes or already have the Lutron codes installed.
Dec 27, 2012 | Lutron MIR-600 Remote Control
The LED indicators on my Lutron Maestro continuously run up and down without stopping and the lights (or fan) will not work? It seems as if the entire switch is frozen... Whats the problem?
1) If this installation was working before, the Maestro has a small pull-out circuit breaker that lets you reset the device. This is called the FASS Front Accessible Service Switch, located at bottom of dimmer where it meets cover plate.
Open sample Lutron Maestro dimmer manual to see FASS illustration
http://www.lutron.com/TechnicalDocumentLibrary/0301106A.pdf
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which apparently excludes CFLs.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on nearby outlet that is on same breaker to see if line has interference.
3) Lutron has customer service numbers:
1.888.LUTRON1 (588.7661)
1-800-523-9466
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 03, 2011 | Maestro Lutron Ir Dimmer Mir-lfqthw...
I have a Meastro dimmer MAW-600 W that is installed, but the light does not turn on and the LED keeps blinking. Any idea what the problem can be?
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which excludes CFLs apparently.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on outlet on same breaker to see if line has interference.
3) I don't see MAW-600 W listed among Maestro dimmers, so I don't have that specific manual.
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
4) Amazon certainly shows the MAW-600 W, in case you need a replacement.
http://www.amazon.com/Lutron-MAW600H-WH-Electronics-Maestro-Dimmer/dp/B000BPCWQE
5) Lutron has customer service numbers:
1-800-523-9466
Feb 02, 2011 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Ok i installed the Maestro IR on a switch that runs a celing fan with a light on it. i turned the power back on in the room and the light was flickering and the fan was unresponsive. please help!!
Lutron Maestro IR shows several model numbers:
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro+IR%C2%AE+dimmer
You posted under MIR600 single pole digital fade dimmer for incandescent and halogen.
Installation manual:
http://www.lutron.com/TechnicalDocumentLibrary/030864b.pdf
If this is not your dimmer, then add a comment with exact model number so I can read that manual and look for trouble spots.
The manual does not say 'Fan'
It appears this dimmer is for incandescent and Halogen lights.
Manual gives Lutron 24hr/7day tech support number 1-800-523-9466
If you do not want to add a comment for more free assistance, and do not want to call Lutron, then take advantage of fixya phone service.
Expert will walk you through the problem for a price.
Dec 25, 2010 | Maestro Lutron MIR-600 IR Satin Color...
How to program control with light switch
If I understand correctly, you have the Lutron Pico wireless control
And you have the Lutron Maestro companion switch or companion dimmer
Pico will not work with ordinary wall switch or dimmer >> it has to be a companion product from Lutron
I have read the PICO wireless manual, and it shows no instructions for communicating with the companion wireless switch or companion wireless dimmer
http://www.lutron.com/Products/SingleRoomControls/MaestroWireless/Pages/Overview.aspx
http://www.lutron.com/TechnicalDocumentLibrary/369-144f_Pico_Wireless_Control_SpecSub%20%286%29.pdf
I have read the 120V Companion switch manual and it shows no instructions for communicating with the PICO wireless control
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Single+Room+Controls&prodn=Maestro+Wireless%C2%AE
http://www.lutron.com/TechnicalDocumentLibrary/030865c.pdf
1-800-523-9466 for technical support
Technical support online appears at page bottom
Normally manuals give you some clue as to how the product works.
The PICO manual says it's easy to control lights (I guess it's easy for mind-readers)
There seems to be no answer or hint when working with the PICO.
I think Lutron tech support is where you go from here.
Let us know what you discover
Oct 22, 2010 | Lutron MRF-VCTX-WH Maestro Wireless White...
How to install
Lutron S2-LFSQ is made to control one ceiling paddle fan & 1 light. Switch will not work on florescent lights.
See manual
To use this product, your fan and light must already be controlled by 2 separate switches.
If you have just one switch that turns on the light & fan together, the S2-LFSQ will not work (without additional wiring).
Okay, you have two switches. One switch turns fan on-and-off. The other switch turns light on-and-off.
Here is wiring diagram from manual: See diagram larger
Here's how to wire:
-Before disconnecting wires from existing switches, mark each wire with tape and pen.
-There is one wire that feeds power to both switches > mark this the 'Hot wire' and it connects to Lutron black wire (if you are unsure about this wire, remove switches, separate wires, turn on power and test each wire to bare ground, tape tester leads to wood sticks so hands are away from power, Tester lights up on Hot wire)
-The switch that controls fan > mark this the 'Fan wire' and it will connect to Lutron Yellow wire
-the switch that controls light > mark this the 'light wire' and it will connect to Lutron Red wire
-Lutron Green wire or bare wire connects to bare ground wire.
Oct 02, 2010 | AMS Lutron S2-LFSQ Skylark Dual...
Dimmer doesn't turn off! Right after I installed a Lutron electronic dimmer switch, it worked fine. After about a week, it wouldn't turn the lights off. The lights just dim to a low level at the lowest...
There is one more thing that you can try, turn the power off from the breaker and wait about 20 seconds, then turn back on. If that doesn't fix it you are probably right about the dimmer being bum. It is very rare that Lutron devices are defective. You can contact them directly and see if you can get it replaced since you no longer have the receipt. You may have to send it to them before they will send you a replacement but it beats spending another $50
http://lutron.com/CMS400/page.aspx?id=24679
Oct 17, 2009 | Maestro Lutron MRF-600MT Single pole or...
Leviton Toggle Touch Dimmer - TGI06-1LB - N/A Logo
35 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
Gene Haynes
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
