Question about Stihl Garden
Stihl MM 55 won't run/start
My MM 55 cultivator will not run. Like all my , Stihl products , carbs have been replaced multiple times and machines have been serviced. I've been working all day just trying to get my machines going because the cost of dealer service is to expensive and to often. I've tried different types of fuel to correct these problems,but nothing seems to help. These carbs will fail after a few uses.
  • 708 Answers
You will have to have extremely clean fuel with stihl carbs. As the orifices are extremely small some are so small you can barely get human hair through them. So make sure you are using correct mixture if it says 50-1 u better make sure you use 50-1. Also make sure the can has no trash of any kind. And main thing make sure the fuel filter is in place and not at all damaged.
Posted on Aug 06, 2017
  • 316 Answers
SOURCE: replace start cord on stihl fs 36
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,MrFixIt,thank you. `
Posted on Feb 18, 2012
bustech17
  • 38 Answers
SOURCE: My Stihl FS85 runs good for about 20 seconds and then shuts completely off. I have replaced the Plug, cleaned out the fuel system and it still does the same thing. Could it be the coil?
Sounds like the main jet or the diaphrams in the carburetor are deteriorated. Remove carb and soak in a good carburetor dip style cleaner and rebuild with a new kit. Also replace the fuel line and filter and use a fresh gas mix.
Posted on Sep 23, 2012
  • 2239 Answers
SOURCE: hi, have a stihl fs 85, runs fine for 10 minutes, then just cuts out. tried cleaning carb, muffler.
Two things spring to mind, fuel tank breather, to rule this out slacken off the filler cap when the machine starts to die, if it picks up again change the tank breather, or the ignition coil is breaking down when hot, this would require a replacment unit.
Posted on Dec 16, 2012
irtlmn
  • 1727 Answers
Check for an air leak... You pressure check the crankcase.
Posted on Oct 26, 2013
qumozheklj
  • 23 Answers
SOURCE: Where can I download stihl fs 55 repair manual or stihl fs 55 service manual?
stihl fs 55 repair manual Complete Service / Repair manual , Diagrams / photos , Circuit diagrams , Wiring diagrams , Schematics , Parts List ,etc.
http://autopartsrepairstore.com/stihl-fs-55-repair-manual-stihl-fs-55-service-manual/
Posted on Apr 09, 2016
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Stihl 180c runs wide open all the time.it has a new carb on it, linkage is fine
Stihl MS 180C Wont Run ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
Aug 14, 2011 - 10 posts - ‎7 authors
I have a Stihl MS 180C that i cannot get to run. I used it all last year and went to use it a few months ago and it didnt seem ... it is not under warranty and i have pulled and pulled with choke on and throttle wide open and still wont start. ... Depending on the carb, some times you can just go for broke and get a ... Stihl ms 180 running rich
Jun 5, 2015
Echo cs-370, they actually work
Oct 12, 2010
More results from www.arboristsite.com
Stihl Chainsaw Troubleshooting Guide · TEK Indoor · Disqus
https://disqus.com/home/discussion/tekindoor/stihl_chainsaw.../newest/
Stihl
Dec 15, 2015 | Stihl Garden
Stihl FS110R trimmer I can't keep it idling
increase the idle speed via the tuning screws on the carb
Apr 15, 2013 | Stihl Garden
Download still sh55
http://www.h-machine.jp/part_list/stihl/stihl_BG%2045,%20BG%2046,%20BG%2055,%20BG%2065,%20BG%2085.pdf
Illustrated parts list of BG 45, BG 46, BG 55, SH 55, BG 65, BG 85
including the breakdown of the C1-s50 and C1-s55 carbs
Mar 10, 2013 | Stihl / Zama Blower Carburetor Bg 45 46...
Stihl hs45 hard to start when started won't rev and cut's out
Most likely a fueling issue, Check fuel line for air leaks or it could be a carb problem.
Jul 03, 2012 | Stihl Garden
STIHL BRUSHCUTTER VERY HARD TO STARTAND WON
Could be a fueling issue, check fuel lined and fuel tank vent. Vents can become damaged and create a vaccum in the fuel tank, stopping the carb from drawing up fuel from the tank.
Jun 07, 2012 | Stihl String Trimmer Brushcutter Service...
What makes my stihl 026 hard to start.had carberator rebuilt two times that didn't seem to help.
You keep putting new parts in an old carb. Just get a new carb and don't be cheap. Your saw will run like new for 40-50 bucks.
Jan 14, 2012 | Stihl Garden
Garden Logo
71 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
