Question about A D S ADS Instant TV Deluxe USB (DHUSBAV705)
Fault number DV0001
Software loaded and hardware installed but when preview or capture (red dot) is clicked a screen comes up saying : DV0001: Unable to initialise usb device - OK.
If you click OK it starts the device but again when you want to capture or perview it says: DW0005: Unable to initialise USB device.
All cables and connections were double checked and are Ok. I am using XP professional.
Please help
Johan de Villiers
  • 1 more comment
  • johand5 Jan 28, 2009
    The solution to my problem was yet to be offered. The idea of reloading & restarting did not produce results. Also the download/update of drivers is not the answer. I still get the same fault reports and connection failures. Johan de Villiers
    I have done exactly as Ginco said but problem remains.
  • johand5 Jan 29, 2009
    Dear Specialists
    The solutions offered so far did not solve my problem.
    Please think again and help me
    Johan
    Brigadier General:
  • 6,966 Answers
Hi and welcome to Fixya,
If the issue exists even after install/re-install, driver updates, latest Capture Wizard, then it is an internal hardware problem. Pls verify that Instant DVD+DV shows in Device Manager and there are no yellow or red markings. If there are or it does not appear, then as earlier stated, internal hardware problem.
If you have used this unit successfully in the past, pls recall if the unit generated excessive heat. If yes, then it is most likely a cold solder issue with the voltage regulators. This especially holds true for Version 1 models. If the unit is relatively new, then a replacement may be in order.
Good luck and thank you for using FixYa.
Posted on Jan 28, 2009
  • Louie  Role
    Louie Role Jan 29, 2009
    Hi again,
    Any updates or developments so far?
    Cheers.
    President:
  • 2,110 Answers
    President:
  • 1,257 Answers
It may be a compatibility issue with XP.Try using vista and see if it works..
  • 19,396 Answers
That happened because you connected USB device before installing software do the following.
1 Hard reset.
  • Unplug USB, and unplug computer from power.
  • If computer is a laptop also remove battery.
  • Wait ten minutes , and reconnect computer to main, or reinstall battery. Do not connect USB yet.
After restarting computer test USB device, if you still get error DV0001, then do the following:
  • Unplug USB.
  • Do a system restore to a date before you connected the USB device.
  • Reinstall Device software completely.
  • Connect device to USB only after installing software, or when asked by device setup wizard.
  • Restart computer.
Posted on Jan 26, 2009
  • 6,487 Answers
This can be a problem with the device software, first thing that you can try here is to uninstall and reinstall the software and if still doing the same thing downloading a updated software from the manufacturer web site will be better to correct the problem,,,
  • 679 Answers
 Ensure that the USB cable is connected directly into the back of the computer and the Instant DVD 2.0 is properly detected within the Device Manager.
  • rockfixya
    rockfixya Jan 26, 2009
    If you are capturing analog video, make sure that you have a USB-2 port. USB-1 is not fast enough to capture analog video. Also, you may need a powered USB port. Sometimes the USB ports on the back of the computer can supply power, but the ports on the front can't. (Or the ports can't supply enough power.) If your source is a DV camera, it should have it's own power.
Webcam will not load divers
make sure that the Webcam is connected properly and is switched on>
then try and uninstall and reinstall the Webcam
Oct 07, 2009 | Gear Head WC330I Webcam
Small screen goes blank when I click on "Start Recording" and I get "record error" I am trying to record to hard drive folder
Disconnect your dazzle then connect it again at the back of your computer. Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. Wait for the new hardware found message comes out and then open your IDVDR again and then do the advance mode. On step number1 choose capture source click the pull down arrow and then choose dvc 100. Turn the power on on your camcorder and run it. Make sure that the video image showed on your preview screen. Try record it again.
Sep 28, 2009 | Pinnacle Dazzle DVD Recorder
How to scan with mac
    1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
    2. Install any necessary software drivers that came with the scanner.
    Note: Not all scanners require the installation of additional software drivers.
    3. Turn on the scanner.
    4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
    5. Select the area of the image you want to scan.
    Figure 1 Preview image with area to be scanned selected
    6. Click Options in the toolbar to adjust settings specific to your scanner.
    Figure 2 Options icon
    7. Adjust any settings in the drawer that appears.
    8. Click Scan.
The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
Note: These are the default options. They can be changed in the Image Capture toolbar.
Jul 16, 2009 | HP Photosmart C6280 Printer
0.008 seconds - no capture, no preview.
Going to the Pinnacle support part of their website in downloads and downloading the latest drivers for the relevant model number worked for me.
Mar 02, 2009 | Pinnacle Dazzle Video Creator Platinum...
Video preview failure
i already install the driver of my a4 625 but when i open it there is a message that there is no capture hardware.pls help me it my problem
Dec 12, 2008 | A4tech PK5
WEB CAM
do you have internet connection?how many months since your pc was reformated?if thats the problem,your system needs to be refrogram.
thakn you!!
May 13, 2008 | Computers & Internet
Dazzle dvd recorder
hi alldown2me
Did u install the software including the patch properly?
what kind of connection did u use? (RCA,ANALOG,Fire WIRE, etc)
Please feel free to reply should you need further assistance.
Regards
andrew
May 05, 2008 | Pinnacle Dazzle DVD Recorder
Installation problems
Did you plug the scanner in before installing the software? Common mistake... Disconnect the scanner, uninstall the software completely, re-boot, open up the Device Manager, Click View-->Show Hidden devices--> Look for any scanner related drivers that are still installed for the scanner (they will moste likely be grayed out since it is unplugged) and uninstall them (Right click-->Uninstall). Re-boot again, install the software, wait for the software install to prompt you to plug in the device. Follow the quick start guide if it came with one. Check the manufacturers web site for updated drivers, software for you model.
Nov 29, 2007 | Mustek A3 USB Flatbed Scanner
Televison & Video Logo
47 people viewed this question
Top A D S Televison & Video Experts
Are you an A D S Televison and Video Expert? Answer questions, earn points and help others
