Question about Tablets & eReaders
My tablet makes a buzzing noise when charging and turns itself off sometimes
My tablet wont turn on or charge
Unplug the Battery, hold the Power button for 10 seconds to discharge any capacitors, Plug the battery back in, Charge the tablet until the battery reaches 100% (Factory Charger preferred), Turn it on. If this doesn't work it could be a bad battery, bad charger or bad USB connector.7 Jan 2014
SOLVED: Why won't my tablet charge or turn on? - Samsung Galaxy ...
https://www.ifixit.com/Answers/View/.../Why+won't+my+tablet+charge+or+turn+on https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=My+tablet+wont+turn+on+or+charge
not saying any off this is going to work for you but read it anyway.
the reason i say this is because i had some one else with the same problem but it ended up it was the tablet itself was faulty.
Nov 29, 2016 | Tablets & eReaders
I cracked the screen on my ASUS memo pad 7 and since then it's been turning itself off. Now it won't turn on again
hi yes I think u need a new screen ring an asus dealer ask for a price to repair it if the cost is to high check on ebay they have some good deals ...good luck
Jun 01, 2015 | ASUS Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
Nov 17, 2014 | Tablets & eReaders
Does anyone know why my Hisense Tablet turns itself off?
sometimes the heat sink is defective, and since it has a safety feature of shutting down to prevent a meltdown. You need to send it to techie and have it cleaned.
Jun 01, 2014 | Tablets & eReaders
My tablet will not turn on
First check to make sure it is charged. Sometimes the charger doesn't stay pushed all the way into the tablet. Second, make sure you firmly press and hold in the power button. It can sometimes take five seconds or more to turn on.
Mar 08, 2014 | Visual Land Connect 7" Tablet
I pluged my tablet in to charger it turned off wont turn back on and makes ticking noise hkc 8" capacitive multi touch tablet duel core processor
It may be that it has to be charged longer, before you try using it when plugged in. it has happened with my tablet as well.
Mar 02, 2014 | Tablets & eReaders
My tablet turns off by itself even though it has 97% of charge!!!!!!!!!!
Make sure the case is not resting on the power button. Also, from personal experience, make sure when you hold it, you hand does not rest on the power button.
Oct 14, 2013 | Tablets & eReaders
Tablet making weird noise
you might have a deffective battery, which is a very common problem to tabs... especially if your using a generic tablet....
Jun 25, 2013 | Wacom Intuos3 6x11 Tablet PC
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
Tablets & eReaders Logo
15 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
