Question about Intel D101GGC Motherboard
Processor fan my processor fan is not working and continu beep but when I am continus refress tha computer processor fan working deer sir my problem solve for you
  • 21 Answers
It sounds like your CPU fan is slowing down with age and thus triggering your motherboards warning 'slow fan' alarm, while it may just need a good clean (remove dust/grime) it may prove much easier to simply replace the whole fan anyway...
Posted on Jan 26, 2009
Continuse beeping on start up
open case and remove the ram modules and then put them back in,sometimes they lose contact and they need to be reseated and of course make sure everything is unplugged first and you are static free,worked for me more than once good luck.
Mar 05, 2015 | Gigabyte Motherboard PhenomII AMD740G AM2...
Emachines won't send signal to screen, when turned on it makes one long continuous beep
The beep signifies an error. But different bioses have different beeps. You can check with the emachine site to tell you what 1 beep on the machine signifies and you can be guided accordingly. Could be bad power supply, connection, peripheral, etc
Sep 01, 2017 | E-Machines eMachines Desktop PC
When I turn on the computer there is no beep and no video
i guess the problem is with you USB or else due to low voltage ,i have experienced these problem once :)
Mar 28, 2012 | Gateway GT5622 PC Desktop
My motherboard GA-8GGEM800 no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
my motherboard 945gs no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
Oct 28, 2010 | Intel Motherboard
System stops working. Task manager show nothing working and then a loud speaker beeep continuously
Is there a sequence to the beeps? If there is then it is telling you the problem with the beeps. For example "beep" "beep" "beep-beep" would be a processor register failure. Also check that the cpu fan is working...it might be overheating if the fan has stopped.
Nov 24, 2009 | Dell Inspiron 6400 Notebook
Computer when turned on will not boot and makes a long beep continuously and then makes like a siren sound
The long beeps probably mean a problem with RAM. So try replacing it. Check whether the CPU Cooler (the fan on top of the processor) is working. If the fan is not working, the processor gets hot, and a siren sound is emitted. Also check whether power unit fan (at the back) is working. If RAMs are replaced and you still get the beeps, the problem may be with the VGA. (The beep sounds help to identify the problem, but the sounds differ with different BIOS models).
Jul 30, 2009 | Computers & Internet
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
My pc is giving continuous beep voice.
Probably some hardware defect. You could try removing unnecessary components. Of course, as a minimum, you need the CPU and memory. If you have more memory modules, you could try them one-by-one, if this is possible with the particular type you use. Please note, some motherboards / memory types require to use particular slots for particular configuration, to use modules in pairs, etc (please consult manual).
Mar 20, 2009 | eMachines D3123 Desktop Computer With AMD...
Continuse restart my computer
Your CPU is overheating
1) Turn off computer and remove case side
2) remove fan from "heatsink" do NOT remove Heatsink "Usually this is stuck with solidified heat paste"
3) clean all dust and dirt from heatsink and fan.
4) vacuum out case Include behind power supply and video card.and any other fans
5) use stiff brush and vacuum outside of power supply
Reboot and see if still restarts if not everything OK
shutdown PC and refit case side.
This is a common problem on a lot of computers as the environment they are used in is usually dusty.
I do mine every 3/4 months and have no problems like this
Please when works give me a fixya
Jan 26, 2009 | Intel D101GGC Motherboard
Intel D101GGC Motherboard Logo
76 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
