Question about Air Tools & Compressors
Need to know pulley size on a ingersol rand 2475 pump
  • 1383 Answers
SOURCE: correct rotation of copressor
Checked all the IR compressors in stock and all turn counter-clockwise facing pulley, however you could check the pump for fan angle on pulley. The fan on the compressor pulley blows air towards the pump. Generally, pumps turn CC because that would allow for the use of gasoline engines which all turn CC. Please email you questions, and Good Luck.
Posted on Jan 27, 2009
  • 98 Answers
SOURCE: ingersol rand model 3000, serial no 9835350,size
If the motor is a 20 horsepower it is pumping app. 80 cubic feet per minute . Here's a good rule of thumb 4 cfm per horse power.
Posted on Aug 06, 2009
  • 41 Answers
SOURCE: I have a Ingersoll Rand Type-30, Mod#2475
when you remove the pressure switch cover,there is a screw on the top screw clockwise means increasing air pressure and anticlockwise means decreasing the drlivery air pressure
Posted on Sep 28, 2009
Testimonial: "Cool!!Thanks!I finally got a "page" on pressure switch. Its not in the regular owners manual. It was like pulling teeth,& had to get it from GRAINGER"
  • 17 Answers
SOURCE: I am looking fo a manual for ingersoll rand t-30
http://company.ingersollrand.com/Pages/default.aspx
Posted on Dec 31, 2009
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
Need to remove t30 2475 pump pully
Hi Mike,
Your problem is very simple please do he following.
1. Remove V-belt.
2. Loosen the lock nut of the compressor pulley.
3. Use a 3 jaw puller to pull-out the pulley.
3. Slowly tighten the puller and thats it.
Hope i can help in your problem,.
Apr 23, 2012 | Ingersoll Rand - Rand Type - 30...
I believe that the motor starter circuit on my Ingersoll Rand 2475 5 hp 80 gallon compressor is incorrect. It's a 30 amp single phase compressor
You should not be pulling over 30 amps. If you are you may have low voltage, incorrect wire size or to long of a run for wire size. I would use a hand held meter and check the amps at full load.
Nov 14, 2010 | Ingersoll Rand 2340/2475 Electric Air...
Ingersall-Rand T 30 Model 2340 Motor overload trips when trying to fill air tank. How long should it take to fill the tank with air with tank empty. If tank is full it may cycle one time when using air.
You need to know the size of the tank before you can figure pump up time from empty to full. It sounds like you have a bad tank check valve. A bad check valve typically causes the motor overload to trip when starting.
May 21, 2010 | Ingersoll Rand 2340/2475 Electric Air...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Hello, my name is Matt and I'm on my second gas operated T30 and the Kohler engine is about to go on this one too. I'm considering mounting the 2475 pump under my truck and running it off of a PTO....
Ingersol Rand compressors are driven by a variety of motors and gas engines. They set the rpm of the pump based on the required cfm /psi output required by the customer and power source. Your compressor has aprox 12- 15 hp gas engine that develops full power at about 3600 rpm of the engine. The pump will most likely be turning about 1000 rpm. Easy to check, just mark both pulleys and count the number of turns of the engine pulley compared to the pump. Pump specifications can be found at www.grainger.com. You will find that most ingersol pumps turn from 650-1200 rpm for max output. You will max pump life if you are able to keep rpms low (600 - 1000 turns). The pump will not lubricate properly if you turn too fast. The compressor needs between 5 and 15 hp depending on the cut-out pressure. Full hp is required as the pump neers 175psi. Good luck with your project.
Mar 27, 2010 | Ingersoll Rand - Rand Type - 30...
Sep 11, 2009 | Ingersoll Rand - Rand Type - 30...
Correct rotation of copressor
Jan 27, 2009 | Ingersoll Rand 2340/2475 Electric Air...
Air Tools & Compressors Logo
27 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
