Question about Dishwashers
Non return valve
When i pour water in my sink waste it goes into my bosch dishwasher which is connected to my sink waste
it is a bosch dishwasher SHV 4313GB/17
Can you tell me how and where to find non return valve
  • 130 Answers
Has it always done this? If so it was an install issue. The tech should have put the drain above the drain with a loop to prevent backfill.
Posted on Jan 26, 2009
Water backs up from the drain in my dishwasher and smells. what is the problem?
Two things can cause this problem:
1. The check valve in your dishwasher may be defective, allowing water and food debris to seep (or run) back into your dishwasher.
2. Your drain hose may not be "mounted up" the way it should be. Look under your sink. Look at how your drain hose is connected to your garbage disposal. If the hose runs down to the floor of your cabinet and into your dishwasher, that is wrong. Instead, it should be mounted up so that water from the sink and garbage disposal would have to flow up first to get into the dishwasher. If you do this, then even if you have a bad check-valve in the dishwasher, it will prevent the problem (or greatly reduce the problem) of dirty water flowing back into your dishwasher.
May 17, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
How do we remove the horrible smell in our Bosch dishwasher?
First check out your model to see if it has a built in garbage disposal, if so, make sure it is not mucked up.
Run hot water down your sink drain while running the sinks garbage disposal. Pour baking soda down your sink garbage disposal followed by white vinegar. Let it sit and foam. Run hot water down sink disposer while running. When finished:
Run empty dishwasher with no soap, let dishwasher fill with hot water to wash and then pour 1 cup of white vinegar into the bottom and resume wash. Make sure you take it through the dry cycle. When finished, open dishwasher and let it air for a couple of hours, longer if you live in humid area. Hope these steps do the trick.
Aug 03, 2014 | Bosch Dishwashers
Clogged Bosch SHU 9920 dishwasher
-Sounds like the pump is not working properly or the drain line you connect to sink directly instead to the breath cap before to the sink. Or the breath cap locate too low.
-Make sure the breath cap is mount higher than the line to the sink. (Or as high as possible) This is to prevent any water from the sink pour into the dishwasher.
Good luck
Mai
Jun 16, 2017 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Dear Sirs, I have a client with a Bosch dishwasher that is leaving a film on all of the dishes. the water valve is working and the drain pump is working. Apparently this has just started. Any ideas?...
Hello
Welcome to FixYa.
Can you provide a model number of your Bosch dishwasher ?
Depending on the model ( i.e. SHU, SHV, SHE, SHX followed by several caricatures etc. ) it can be several possibilities so I`ll hold off generalizing and instead try and speak specific about your model.
Regards,
Macmarkus :)
Sep 23, 2010 | Bosch Dishwashers
Water in the bottom and not working
Check for a clogged drain (e.g.: via drain hose), or a water pump malfunction due to foreign obstruction (e.g.: glass, etc).
Note: If you changed a food waste disposer (kitchen sink area) and did not remove "plug" from disposer for dishwasher drain hose (assuming dishwasher drain hose connected to food waste disposer), then water cannot drain from dishwasher.
Apr 14, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Water in bottom of dishwasher
Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Feb 28, 2010 | Bosch Dishwashers
Will not empty water, and stops before end of cycle. Doesn't appear to be any blockages. Filters have always been in place, and appear clean on inspection. No twists or sharp bends in drainage pipes.
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jan 25, 2010 | Bosch Dishwashers
Just had bosch dishwasher installed by plumber but it is still not filling up with water. it works after we poor a pot of water in it.
Locate the hot water supply hose under the sink that connects and follow it over to where it will connect to the back of the dishwasher. Look for sharp bends in the hose. There should be a valve where the hose connects to the under-sink plumbing. Rotate that valve counter-clockwise to assure that it is open.
If the problem continues, the solenoid valve may have immediately failed. That valve is just behind where the hose connects to the dishwasher.
Good Luck!
May 08, 2009 | Dishwashers
I have started hearing a gurgling sound in my diswasher air vent when I run water in my sink. Why has this begun happening? I have an /estate dishwasher Model TUD7000Y-0
Sounds like your waste water drains could be backing up and pushing water back into the dishwasher.
Firstly try pouring Mr Muscle sink and plughole un-blocker down the sink and leave overnight next morning pour boiling water down the sink and your pipes should be squeaky clean. Hopefully this will improve the flow and prevent gurgling!
Feb 21, 2009 | Miele 24 in. G870 Built-in Dishwasher
Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Nov 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
173 people viewed this question
Top Dishwashers Experts
