Question about Kohler Finial Traditional Widespread Lavatory Faucet with Lever Handles in
Kohler k-310 repair
How to disassemble
How do you stop a kohler men urinal stall from consistently running?
Usually this is caused by a sticky valve. The "low-tech" repair method is to just thump the top of the valve fairly hard with your fist. The correct method would involve disassembly and cleaning of the valve interior, or even possibly replacement.
Oct 17, 2015 | Kohler Home
This shower has 3 body spray jets. The lower jet does not work. I need to remove the lower one to see if there is debris in the line, blocking it. It is a Kohler k 8002 cp body jet. How do I disassemble it...
There are some clips on the top of the spray head that fasten it into place. I found this pic that may help and your Kohler owner's manual should also have more info.
Mar 19, 2015 | Kohler Electrical Supplies
How do I disassemble a Kohler kitchen faucet
Remove sprayer and hose from faucet body.
Remove handle and cartridge.
Pull up on body.
Replace parts and reinstall in reverse order.
Aug 31, 2014 | Kohler Model 10433: Fort® Single-control...
How to disassemble a kohler kitchen faucet?
Go to the kohler web site for instructions. If nothing you can google this and probably get a utube video to show you how it is done.
Sep 15, 2017 | Kohler K-10433-bn Brushed Nickel Single...
How can i disassemble the sprayer handle on my kohler a112.18.1m kitchen faucet
1-800-4KOHLER
http://www.us.kohler.com/us/static/helpTopicsHelper.jsp?helpId=728
Aug 27, 2012 | Kohler Plumbing
When you depress the air presure butoon on the kohler whirpool tub a clicking sound is heard but the motor does not run. There nis powewr to the receptacle that the pump/motor is connected to.
What you need is a new air switch for the back of the motor. The air tubing connects to it on the motor. that is probably what is clicking when you push the air button on the top of the tub. Once you change that air switch you will be back in HOT WATER !!
Should be a TBS-310 or TBS-301 latching air switch is the one you need. Either of those models will work in a Kohler pump.
Feb 04, 2011 | Home
I have a Kohler bathroom faucet with 2 lever handles. I have the replacement stems but I am not sure how to remove the handle. There are no caps or scews on the handle to be removed. Is the handle just...
I just watched a you tube video. It looks like you have to loosen the cone shape at the base of the handle and the whole handle will come off. Hopefully this helps.
Feb 11, 2018 | Kohler Fort© Widespread Lavatory Faucet...
Kohler Finial K-310 Widespread Lavatory Faucet. How do I remove the Lever Handle (77887) and Bonnet (75601) so I can replace the washers.
should be able to turn the bottom piece under handle and it comes off along with handle..dont think theres a little "cap" that comes off at top of handle..but mite try prying it off it just has an o ring holding it in place and screw will be under that
Nov 24, 2010 | Kohler Finial Traditional Widespread...
How to disassemble a Kholer Rite-Temp Shower Faucet to repair a dripping shower head. It has a one handle design with no obvious set screws. Any where to look at a scamatic to show how it's put together?
Call Kohler, most of their products have lifetime guarantees also come with diagram. Look for a set screw either beneath (underside) the handle or under a center cap on the handle. Some are obvious, others appear to be part of the design, raised outline, temp indicators etc.
Aug 20, 2009 | Kohler Bathroom Accessory Set with Classic...
Kohler Finial Traditional Widespread Lavatory Faucet with Lever Handles in Logo
96 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
