My toshiba satellite laptop is getting hanged very frequently can say every 2 min. Can any one help me out how to solve this problem
  • Misterixas May 11, 2010
    Does your anti-virus program is able to find any viruses or threats? Have you tried on-line scanners then instead? For example"
    http://www.kaspersky.com/virusscanner
    http://www.eset.com/onlinescan/
    or similar
    Sometime the best sollution is to backup all your important data (to flash drive, CD, DVD,...) and reinstall a fresh copy of Windows
  • Dan rogers
    Dan rogers May 11, 2010
    Have you run an anti virus or spy ware program on your machine lately?
    Novelist:
    Champion:
  • 201 Answers
Try Booting int safe mode with networking
(Tap F8 while turning on your computer, don't stop tapping F8 until you get to the Advanced Boot Option window. Use your Up & Down arrows to get to Safe Mode With Networking and hit enter, enter to you Operating System and sign in as Admin or Owner)
Once in Safe Mode with networking see if the PC hangs on you.
open you Internet and download MalwareBytes to help remove any Malware that might be hanging you computer in normal mode
http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
(copy & paste link above into address bar)
After running MalwareBytes in safe mode re boot your computer into normal mode and run a MalwareBytes scan in normal Mode until no Malware is found
Good Luck
Dr Geeks MD
Posted on Jan 26, 2009
Hangs Toshiba Satellite P505-S8940
you can do either of the following to solve the problem
  • reinstall the computer with a Operating system that can ran under your laptop hardware requirements
  • cut and paste you files in the desktop to your drive D to offload drive c of your PC
  • increase your PC RAM size
  • uninstall software you dont nedd
Jul 06, 2014 | Toshiba Satellite P505-S8940...
It frequently hangs and slows dow but left for 10 min it will recover
Download a utility programme called asc-setup from IObit.com THis is a freeware utility that will repair your registry errors and much more if you purchase the whole system.
When you have run it go to toshiba.com and download the latest drivers.
That will sort your problems out for you.
Feb 10, 2011 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite Pro L300 PC Notebook in battery the set is OK but when I connected ac power the set is hang on or restarted frequently
you should have your unit check professionally, as it can be cause by multiple problem.
1. laptop fan
2. memory problem
3. voltage problem.
either way, its best that you try to have it check thru the toshiba service center.
Nov 13, 2010 | Toshiba Satellite Pro L300 Notebook
My laptop hangs frequently
Under Power Options change the power Scheme to "Minimal Power Management" and I m sure the issue should be resolved. Thanks.
Jun 17, 2010 | Toshiba Satellite A205-S4617 Notebook
Shut down problem
the fan/heatsink asembly is most likely clogged .. causing the thermal controller to kick in a thermal overheating warning and shutting down the laptop
Jun 13, 2010 | Toshiba Satellite A100-S8111TD Notebook
My Toshiba laptop hangs in 2 -3 mins of starting
Ok at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems.
support.microsoft.com/kb/306084
Apr 12, 2010 | Toshiba Satellite A135-S2276 Notebook
My Toshiba Satellite PC hangs when I insert any USB device
To reinstall USB drivers, you need to reinstall the system, as USB root hub drivers are built in on Windows.
Tray first removing laptop battery and unplugging AC charger for ten or fifteen minutes, this will get rid of static charges that can cause USB not to work.
If that does not solve the problem then you need to reinstall Windows, in this case, try a system restore first.
If all that still does not work, then there is an hardware fault, in that case you often need to replace the motherboard.
Jan 02, 2009 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
