Makes loud noise then stopped
Now it cannot turn on but the light still come on the panel. If you set it to do a wash cycle it appears to go through the cycle if you only look at the lights. The washer motor only moves for about 3 seconds then makes a noise and stop working.
    Sergeant:
  • 291 Answers
You really need to get a look at the motor to see what's going on. If you give me the model number i can likely find you info on removing panels and what-have-you.
Posted on Jan 20, 2013
  • 641 Answers
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
natengel
  • 19 Answers
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Posted on Nov 05, 2007
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: washer flashed f-21/ stopped in the middle of
You have to call the serviceman
Posted on Aug 15, 2009
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Makes loud noise when on spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 09, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Water draining makes loud noises
if water isn't draining properly the cycle will stop thereon check the drain pipe
Oct 12, 2009 | Washing Machines
Kenmore Washing Machine 82110 - Loud Noise
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Mar 31, 2009 | Kenmore 22422 Top Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Noisy dishwasher
SOME DETERGENT DISPENSERS ARE ACTIVATED BY A SOLENOID THAT IS ELECTRICALLY CHARGED. IT WOULD BE POSSIBLE THAT IS WHERE THE NOISE IS COMING FROM. IF YOU WANTED TO CHECK, REMOVE THE DOOR PANEL AND SEE IF THERE IS A ROUND ITEM AT THE DISPENSER ASSEMBLY WITH TWO WIRES ATTACHED TO IT. PUT THE DISHWASHER INTO A CYCLE AND WHEN THE NOISE APPEARS, GENTLY PRESS ON THE SOLENOID TO SEE IF THAT IS WHERE THE NOISE IS COMING FROM. REPLACE THE SOLENOID TO SOLVE THE ISSUE.
BE SURE ALL RETAINING SCREWS ARE TIGHT.
Apr 03, 2008 | Dishwashers
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
