Question about Video Cameras
I NEED PINOUT FOR 8 PINS AV CABLE FOR GRUNDIG CAMCORDER VS-C40
ROUN CONNECTOR IN THE FORM OF MINI DIN WITH 8 PINS IN PART OF CIRCLE
SOURCE: Canon ZR800 MimiDV Camcorder
I have the same problem, here's a 'sort of' solution. First check to see if your computer has a slot where you can plug in a PCMCIA card. (This is a thin slot about 2" wide, which probably came with a plastic blank inserted in it, which must be removed before using the connection. This type of connector is very common on laptops, less common on desktop computers. If your computer is a laptop, the PCMCIA slot is probably on one side or edge of the computer.) So, if you have a PCMCIA slot, you can buy a PCMCIA / Firewire card that plugs into the PCMCIA slot and provides you with one or two Firewire connections. Look on Ebay, these can be had for under $20. You would also need a cable with the tiny USB connector on one end (which plugs into the small female connector found uinder the gray plastic cover on the side of the ZR800) and a 6-pin Firewire connector on the other end (which you would plug into the PCMIA / Firewire adaptor card mentioned earlier.) When shopping, you may see IEEE 1394 terminology - this is the same as Firewire.) By the way, the adapter card may come with the necessary cable; see what you get before buying an additional cable separately. You will also need some software - I'm using Windows Movie Maker, which is probably already on your computer. If not, you can download it for free from Microsoft. Plug in the adapter card and turn on your PC. You should get a 'new hardware' message when it boots up. Wait for the boot up to finish, then connect the ZR800 via the cable to the PCMCIS / Firewire card and turn on the camera. You will get another 'new hardware' message as Windows recognizes the ZR800; wait a while until the 'Your new hardware is installed and ready to use' message appears. When the camera is recognized, you may see a window asking what program you want to use to capture video - select Windows Movie Maker. Once it (Movie Maker) starts up, get your camcorder tape ready, click 'Capture from video device' on your PC, then click 'Start Capture'. It will create a file (you pick the name) on your PC from the camera. You can use Movie Maker to edit, re-sequence the scenes, etc. (You can also buy video editing software if you want fancier features than Movie Maker provides.) Now here's the catch - why my initial statement says this is a 'sort of' fix. I hooked up my ZR800 as described here to a one-year-old Gateway model W323-UI1 laptop, and the video captured from the ZR800 contained many ramdonly blinking colored pixels superimposed on the movie and the audio has lots of static. When I hooked it all up to an older Dell Inspiron 8200 laptop, it worked great. Hope this helps, good luck!
Posted on Feb 22, 2008
SOURCE: Want to transfer videos from a mini DV cassette to computer.
YOU NEED THE SHARP CD-ROM TO LOAD THE VIDEO DRIVERS ON YOUR COMPUTER TO RECOGNIZE THE CAMERA...PART # IS CDSKAA028WJ01
Posted on Jan 02, 2009
SOURCE: Replacing a Blaupunkt Reno with Florida
How can i take my carradio out, and replace it
Posted on Feb 26, 2009
  • 1039 Answers
SOURCE: Need input connector (13 pin din?) pinout.
Call Bose. Do google search. They sell accessories on line. They are vry helpful.
Posted on Apr 25, 2009
fixyathing
  • 341 Answers
SOURCE: Describe your Sony BRAND DCR-DVD 602E
if you want to connect it a PC you need a video capture device to make use of the s-video and the sound but the video quality is limited to s-video only unless you want to make it as a webcam sort-of. If you want store the video in a computer you can copy the DVD content of the CD into your computer's hard disk.
Posted on Aug 10, 2009
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
I need the connector cable for a yamaha tcd av1 and need a part number please any help is appreciated
The connector appears to be an 8-pin mini-DIN connector. http://en.wikipedia.org/wiki/Mini-DIN_connector#8-pin
I got one from an old Apple system, but I haven't been able to get my TCD-AV1 to power on. It may be due to another problem, though. Hope this might help!
Feb 19, 2011 | Yamaha AV-1 Shelf System
No sound
To answer this one, we'll need a lot more information. The following
1. Verify your cable. There's no way to post a picture so we'll try this in text. Looking at the 5-pin DIN (called P1) with the pins to the top, number them 1 through 5 from left to right (regardless of how they may be numbered on a connector as it is unmarked on the cable). Looking at the 8-pin mini DIN (called P2) with the key at the top, number the top row 1 through 3 (left to right in all cases), the middle row 4 through 6 (pin 6 will be the one separated by a gap from the other two), number the bottom row 7 and 8.
Now, make sure that continuity exists. This is how my cable was wired as follows: P1-1 to P2-7, P1-2 to P2-8, P1-3 and P1-4 to P2-6, P1-5 to P2-1. If you do not show that each wire is good, then you either have a damaged cable or audio is not being output by the Bose control unit or your system uses a different cable wiring, which means that you will need to verify that your cable connects each 5 pin DIN to some on the 8 pin mini DIN
2. Make sure that a headphone is not inserted in the headphone jack on the side. If it is, then sound in not connected to the rear ports. It may sound silly, but someone may have connected headphones and nobody realized that they're still connected.
3. Do you have an oscilloscope? If so, then you'll need to insert wires into the 8-pin mini DIN connector for the zone you're using. Using the pinouts from step one for the cable connector will create a mirror at the Bose jack as follows, left to right, top to bottom 3, 2, 1 - 6, (gap) 5, 4 - 8, 7.
Audio comes out at pins 7 and 8. So connect your scope at those points and ground the probe by clipping it to one the RCA shields. Turn the unit on and make sure that you have a source producing signal, such as a disc or a radio station and see if you see signal. The output at these pins appears rather low, so you set your scope sensitive enough.
My Bose produced audio, but also clicking at an increasing frequency and amplitude as the unit heated up, that results in a lot of noise. I verified the wiring and output with this method.
Feb 18, 2011 | Bose Lifestyle 20 System
Someone gave me a YST-MS50. The left speaker (no controls) does not work. It is not the speaker or the cable from the main unit to that speaker. I find that only 7 of the 8 wires in the 8 pin cable going...
If you don't get it to work would you be willing to sell me the right satellite speaker with the controls? email me: red...4..dsc..@....g..mail.com... (just take out all the dots)
Dec 05, 2010 | Yamaha YST-MS50 Computer Speakers
Does anyone have the pinout for the subwoofer cable
PIN 1 L. PIN 2 R. PIN 3 SL. PIN 4 GRD. PIN 5 SR.PIN 6 SW.PIN 7 C. PIN 8 P.ON
Apr 15, 2010 | JVC TH-C40 System
Is the system cable wired as a serial connector
u can get one from cablesondemand.com 8 pin mini din male/male
Oct 19, 2009 | JVC TH-M303 System
Apr 24, 2009 | Audio Players & Recorders
Hiii...
This is a PIC mybe can be help you...
Thank's
Jan 27, 2008 | Blaupunkt PA4100 Car Audio Amplifier
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
