Question about Acer Extensa 5620 Notebook PC
Wireless key which key to start wireless
  • 55 Answers
Hi, take a look at this link, its the user guide for this model:-
http://static.compusa.com/pdf/Acer_Extensa_5620_5610_5220_5210_NotebookPC-UG.pdf
Pages 32-33, there should be a switch on the front of the laptop to switch it on/off.
Hope this helps.
Posted on Jan 26, 2009
Where is the wireless button located on bytespeed PC
Check the function keys (F1, F2, F3, etc) for a "wireless" icon. Then when you have found it, hold the "Fn" key (lower left hand side of the keyboard) first and try toggling the function key until a menu comes up or the wireless starts to work.
Sep 17, 2014 | Computers & Internet
Wireless Key
where the battery goes inside, make sure the solder is well connected to the clip that holds the battery in place. If 1 side is lose re solder it with a solder gun just heat up the old silver.
Apr 08, 2014 | 2009 Toyota Yaris
WBR2310 says network cable unplugged
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 21, 2012 | D-Link RangeBooster G WBR-2310 Wireless...
Emachines wireless not working
Try looking in the program list for the program that starts the wireless. Click Start/Programs and look for the program that drives the wireless and open it.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 11, 2012 | E-Machines M5312 Notebook
Troubleshooting wireless home network using windows xp
To Configure a Wireless Connection in Windows XP, Follow the Instructions Outlined Below.
  1. Click the Start button, click Network Connections, and choose Show all Connctions.
  2. Click the Wireless Network Connection icon with your right mouse button, then choose View Available Wireless Networks.
  3. Choose the name of the 2Wire access point from the Available networks list.
  4. In the Network key field, type the hexadecimal key to access the wireless network.
    Note: The hexadecimal key and wireless network name should already be set up on the 2Wire device. Use the key that you set up on the 2Wire device.
  5. In the Confirm network key field, type the hexadecimal key to access the wireless network again for confirmation.
  6. Click the Connect button.
Apr 15, 2010 | HP Pavilion m7680n PC Desktop
How to turn on the wireless capability by using a combination of function keys. Have re-installed the driver and turned the switch to on position but windows could not detect.
Make sure Windows is set to manage your wireless. Control Panel --> Administrative Tools --> Services
Make sure "Wireless Zero Configuration" is started, and is set to Automatically Start.
Good luck.
Mar 08, 2010 | Sony VAIO VGN-N250E/B Notebook
Wireless
You also might want to check that your wireless hardware switch is turned on. Press and hold down the "function" key on your keyboard, then hit the F2 key.
-Glenn
http://mysticsofthechurch.com
Jan 03, 2010 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Zero wireless configuration has been disabled on presario
Follow this procedure to stop and start the Wireless Zero Configuration service in the Windows XP Operating System:
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type cmd .
  3. Press the ENTER key.
  4. In the Command Prompt window, type net stop wzcsvc .
  5. In the Command Prompt window, type sc config wzcsvc start= auto .
  6. Press the ENTER key. NOTE: The [SC] ChangeServiceConfig SUCCESS should be displayed.
  7. Type net start wzcsvc .
  8. Press the ENTER key. NOTE: The Wireless Zero Configuration service was started successfully message should be displayed.
  9. Type exit .
  10. Press the ENTER key.
Jul 29, 2009 | HP Computers & Internet
My wireless adaptor can not find my wireless router
Please check tour wireless adapter if its working and properly installed in your computer. Here's how to do it;
Checking Device Status on the Device Manager
For Windows 2000 or XP:
1. Click on Start, go to Settings and then Control Panel.
2. Click on System, go to Hardware and then Device Manager.
3. Click the (+) sign on Network Adapters and select the adapter.
4. Double click on it and read the Device Status.
If your wireless adapter is not working and installed properly, you have to re-install the wireless adapter software driver. When the wireless adapter is already properly installed you can follow this steps below;
Enabling Wireless Zero Configuration Utility
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 10, 2009 | NetGear WGR614 Wireless Router
Network key
if you can still detect your network name then try to connect to it. access also the router settings to double check the wireless settings in it particularly the network name and network key. make sure also that the wireless zero configuration (WZC) of your windows is running or started in the services menu.
Aug 09, 2008 | NetGear RangeMax WPN824 Wireless Router...
Acer Extensa 5620 Notebook PC Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
