Question about Sharp LC-52LE700UN AQUOS 52 Class 52-1/32 Diagonal Widescreen LCD Television, Black, Full HD 1080p 1920 x 1080 Resolution, Brightness 450 cd/m2, Full Array LED Backlight System, Viewing Angles 176 H / 176 V, Aspect Ratio 16:9, Response Time 4ms, Audio Syst
How to turn HDMI auto view ON ? - Sharp LC-52LE700UN AQUOS 52 Class 52-1/32 Diagonal Widescreen LCD Television, Black, Full HD 1080p 1920 x 1080 Resolution, Brightness 450 cd/m2, Full Array LED Backlight System, Viewing Angles 176 H / 176 V, Aspect Ratio 16:9, Response Time 4ms, Audio Syst
Mitsubishi WD-60C9 changing inputs on its own whats the cause of that?
HDMI auto is ON. Go to menu settings and turn OFF auto HDMI. That will stop the auto switching. Regards.
Aug 18, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Hdmi screen format problems
try it on av tv it may view and explain briefly i cant understand
Dec 08, 2007 | Denon AVR-3806 Receiver
How do I turn on my hdmI settings on my Panasonic 42 inch Tc-p42u1.
That is unusual. HDMI are usually auto-sensing. Modern TV sense when a cable is plugged in
Mar 03, 2015 | Panasonic Televison & Video
View mode changes when switching tv off then on
If this is the correct tv model number LC42D62U and if you are connecting it to something with an hdmi cable, and it is on one of the hdmi inputs then you need to change the settings. Press the menu button--->scroll to setup on the right--->scroll down to hdmi setup and press enter to select--->If auto view is not highlighted already highlight it then press enter--->disable it then press enter--->press exit or menu menu to exit
Apr 23, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screen is not in digital mode for display it is in analog mode. we have a 64 bit computer from HP
Has it got a HDMI cable in it or the "standard" cable?? If you buy the HDMI cable (Provided the PC has the same port) it will auto view in Dig mode.
Like this one
http://zedomax.com/blog/wp-content/uploads/2008/09/dvi.jpg
or standard like this
http://www.varologic.com/blog/images/Gold_VGA_Monitor_Cable.jpg
Mar 12, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Just connected sky via hdmi through denon 3310 and no sound is coming through the tv. Also do i need to have amp on to view sky via hdmi?
ensure that HDMI is selected in your sky settings.
you would not need an amp at all just to view sky, only if you were routing sound to say a surround system.
Are you only getting no sound from the tv? or are you getting sound via the amp but not from the tv?
Nov 22, 2009 | Denon AVR-3805 Receiver
What to do with my Ps3??
Your PS3 auto-adjusted to the HDMI Input cable, so you will need to find somewhere that you can either get an HDMI cable or a HDMI TV, so you can view the screen. Then you can hook up the A/V jacks and go to your Videa and Audio Output Settings and choose them, disabling the HDMI hookup selected. Then you'll be back in business!
Sep 29, 2009 | Video Game Consoles & Games
Screen flicker when selecting Blu-Ray player w/ HDMI-1 selected.
Something to remember is that most HDMI setups on TV's have what is called a DVI/HDMI port, I would suggest not using anything on that port that isnot converted from DVI to HDMI. I bet if you look, that HDMI 1 on yours....
Feb 10, 2009 | Mitsubishi WD-60735 Projection Television
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Sharp LC-52LE700UN AQUOS 52 Class 52-1/32 Diagonal Widescreen LCD Television, Black, Full HD 1080p 1920 x 1080 Resolution, Brightness 450 cd/m2, Full Array LED Backlight System, Viewing Angles 176 H / 176 V, Aspect Ratio 16:9, Response Time 4ms, Audio Syst Logo
26 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
