Question about Carex Roller Walker
How to fold a carex walker
Folding
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
Why is the cure for cancer so elusive?
Why
because there are so many different types of cancer and so many causes for those cancers
Add to that equation the fact that there are so many dna types and you have your answer
Jun 03, 2016 | Medline (Breast Cancer Awareness), Deluxe...
How do I get a manual for a used Carex roller waller?
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCcQFjAB&url=http%3A%2F%2Fwww.carex.com%2FitemFiles%2FA222_Instructions.pdf&ei=IMgiVJmkB-KIsQTrmYGACw&usg=AFQjCNFDWya3wOrkLhVpslWpgBHD4iUL3g&sig2=B_d1UyX2z5I2m0phHBRC4g&bvm=bv.75775273,d.ZGU
this is the direct download link (it should auto start downloading)
if this link is not active any more please search for:
"carex roller walker pdf"
Hope that helps. and if so please take the time to click "yes" so others know the advice is good
Jun 15, 2014 | Carex Roller Walker
What is a folding table?
A folding table is a two or four legged table that can be flattened via hinges on each of the legs. Folding tables are very convenience because they tend to be very light weight and can save space.
May 29, 2012 | Furniture
I have lost a back wheel from my carex A226-00 transport chair. Is there a place to find a replacement?
http://www.bing.com/shopping/carex-urethane-walker-wheels-with-leg-3/p/6EAA4B4FEA85611A5006?q=carex+wheelchair+wheel&lpf=0&lpq=carex%2bwheelchair%2bwheel&FORM=ENCA&lppc=16
Mar 23, 2011 | Carex Lightweight Transport Chair...
What is a Folding Bicycle?
A folding bicycle is a bicycle that folds for convenient storage and portability. The perfect folding bike would be one that rides as well as a quality full-size bike, folds in seconds, weighs less than 10 kg (22 lb), and folds small enough to fit under a bus or train seat.
Dec 16, 2010 | Cycling
My carex roller walker a233 brakes won't lock. Its brand new.
hi if its brand new I would take it back & get them to adjust the cables to the brake...cheers
Oct 26, 2010 | Carex Health & Beauty
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Circuitry open/shorted.
  • Damaged folding top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Parking brake not engaged.
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top motor upper and lower hose .
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Damaged fluid reservoir.
  • Go to Pinpoint Test D.
Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Jan 04, 2009 | 1989 Ford Mustang
Grip 'n go walker instructions
Grip 'n Go Folding Walker
LINK: http://www.safety1st.com/product/detail.asp?ID=2827#Instructions
Apr 24, 2008 | Baby Gear
Carex Roller Walker Logo
85 people viewed this question
Top Carex Health & Beauty Experts
Tom Chichester
Mister Danger
Jeff Tilburn
Jeff Tilburn
Are you a Carex Health and Beauty Expert? Answer questions, earn points and help others
