Question about Garden
My cub cadet model 5234d wont go forward or reverse
It wont go forward or reverse
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
  • 109 Answers
SOURCE: cub cadet 2160 PTO problem
Yes, there is a switch on the motion lever on the transmission, but there is also a relay switch that is taped to the fuse under the hood of the mower...if this goes bad, the deck will not come on
Posted on Jun 03, 2009
  • 16 Answers
SOURCE: i have a cub cadet model 1450 hydrostatic it will
2 valves on top of trans under finders
Posted on Oct 17, 2009
SOURCE: cub cadet starts but won't move forward or reverse
What model? I have a 1554, that I just took to the dealer, for repairs, for the same thing. The motor starts, the blades engage and cut, it just stopped moving forward, or reverse. If I remember, I'll get back on here and let you know, unless you already know?
Posted on Apr 22, 2010
Have a Cub Cadet riding mower that will not go in reverse or forward. Model 13AP11CH709 and says 1046 on it
Serious tranny issue needing repair. Check the obvious - linkage connected?
Aug 22, 2017 | Cub Cadet Garden
Cub 5234d shut down like you turned key off now it wont start
Check all your safety switches. There is likely one under the seat. Mine has one in the lever area that activates the blades. Also one if you don't push the clutch. to start. Mine also has one if you put it in reverse and don't release the cutting blades.I undo mine one at a time till I find the bad one. Of coarse put them back before operating the machine.
Dec 14, 2016 | Cub Cadet Garden
Cub cadet lawnmower wont go forward or reverse when you press pedal you here a grinding sound
what ever model cadet ride on mower
needs inspection and or repair
electric clutch system fitted on these
or drive part has failed
might just be a bearing
May 31, 2016 | Cub Cadet Garden
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
How can I get an Owners, Operation Manual for a cub cadet, series 5000, Model 5234D Diesel Tractor
You can download it here:
http://www.manualslib.com/manual/33979/Cub-Cadet-5234d.html#manual
Feb 05, 2015 | Cub Cadet Street Sign- tractor lawn riding...
Proceed wont reverse has forward gears
sounds like the reverse band in the transmission has gone have you checked the fluid level if its ok dose it look black and smell burnt if so you need to have it checked out
Sep 18, 2014 | Cars & Trucks
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
What could the problem be with 1999 villager wont go forward or reverse?
I forget the name, but it could be the shift connecttion. It the connection point behind the shifter in the car and the transmission. The port disconnected mine in my car cause they couldn't figure out how to shift it. It basically put the car into nuetral. No forward no reverse. But engine runs fine.
May 20, 2014 | 1999 Mercury Villager
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
