LE46M86BD vertical stripes
I've had this tv for 10 months and it has suddenly developed this fault. The entire screen is full of thin vertical stripes of many colours. After about 15 seconds it then goes off then comes straight on again with the same screen. It did occur shortly after connecting a new AV receiver, but I can't believe that would have caused it. Ihave unplugged all cables but the fault is still there.
silly girl
  • 513 Answers
SOURCE: sansui picture fault
Usualy a problem with the LCD screen itself, that takes replacing the whole screen to fix. Sorry. Could also be an internal connector that has gone bad. There are tiny transistors on most displays that control whole rows and columns. It sounds like one went bad, causing a dead, or constant on, column. Unless you are REALLY handy, it will probably need to go to a service center for repair, which could be very expensive. Try flexing your screen - wrap a non-fibrous cloth around your hand and squeeze the screen lightly all around the edge. If you find a point where squeezing the screen makes things better or worse, explore that point further. Squeeze just hard enough to make a white area go light grey or yellow. It's safe to squeeze gently with something fluffy when the computer is turned-on. Could be a cable problem - either the cable is not making a good connection at one end, or the cable itself may have been crushed and one of the lines in it broken. Replacing the cable is far cheaper than replacing the display. Good luck
Posted on May 17, 2006
lukster
  • 217 Answers
SOURCE: black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
Posted on Feb 17, 2007
lukster
  • 217 Answers
SOURCE: half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
  • 103 Answers
SOURCE: blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Posted on Mar 03, 2008
kitsuneki
  • 7 Answers
SOURCE: green vertical stripes down right hand side of screen, no picture
Unfortunately this means that your TV may be damaged. I would suggest talking to a professional or consider replacing your TV depending on the cost of fixing it.
What it means is that the power to that line of LCDs in your screen is 'stuck' and it is generally not user-serviceable.
Posted on Jan 23, 2009
My screen has a thin, vertical, black stripe about one inch over from the right. It also has a tiny red vertical stripe next to the black one, as well a few blue ones.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 04, 2016 | Insignia Televison & Video
What is wrong with my Sanyo TV?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 03, 2016 | Sanyo Televison & Video
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
Main power supply regulator board can cause this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. any Ideas ?
Toshiba Qosmio G20-117 laptop computer. The display has developed a thin, vertical white line the entire height of the screen about 2cm from the left-hand edge of the screen. Is this a software (screen...
It's a hardware fault, you will normally notice if you push on the screen at the top of the line it will disappear, unfortunately you will have to replace the screen.
May 17, 2008 | Toshiba Computers & Internet
Big vertical tinted stripe on screen
Need more information:
Can you isolate which color is causing the banding?
Is there something ON the lense itself?
Is the projection mirror broken or bent?
S
Dec 12, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Nov 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Black 3-4 inch wide Stripe
this problem is a bad panel it needs to be replaced in some cases the panel is under warranty. check your warranty.
also the E and F buffers could be at fault I would have these replaced first.
Oct 14, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
No picture on 42" plasma TV.
take your tv to a tech the tv is having problem in the color circuit and the vertical circuit.
Apr 13, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
