Question about Sharp AL 1631 Copier
I'm a technician. I need your assistance to the solution of F5 in Sharp AL1216.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
F5-02 - Exposure lamp blown
**ALWAYS DISCONNECT POWER BEFOE WORKING ON MACHINE****
Check the exposure lamp, if defective replace.
Check inline exposure lamp fuse, if defective replace.
Also check flat cable from CCD to MCU PWB , if cut or defective replace.
Last -- brds (boards)
Posted on Jan 28, 2009
How to clear F5 error in Sharp AR-5316E, my technician have already cleaned the glass and all the optics in the scanner including the lamp and the white strips on bottom but still the error remains.
F5 errorContent Copy lamp error
Detail Copy lamp voltage detection error
Cause Power unit trouble, Copy lamp trouble
Inverter trouble, MCU PWB trouble
Check and remedy
Replace the power unit.Check the copy lamp ON with SIM
5-3.
Replace the copy lamp.
Replace the inverter.
Replace the MCU PWB.
Aug 31, 2012 | Sharp AR-5316 Advanced Digital Imager...
I have a al1216 copier of sharp. Now didn't anything flashing only 4/h frequently
H4 00 Content Too cold fusing section Detail The temperature does not reach the preset value within the specified time (3 min. in usual modes; 5 min. in curl correction mode.) after the power relay is turned on. Cause Thermister defective Heater lamp defective Control PWB defective Thermostat defective AC power supply defective Interlock switch defective Check and remedy Check heater lamp for blinking with SIM5-2. If lamp blinks properly: Check thermister and its harness. Check thermister input circuit of control PWB. If lamp does not light: Check heater lamp for broken wire and thermostat for operation. Check interlock switch. Check lamp control circuit of AC PWB and control PWB. Clear the trouble with SIM14
Nov 02, 2009 | Sharp Office Equipment & Supplies
Sharp AL-1217 Driver for Windows Vista
try the driver for AR123E at
http://www.sumthai.com/s0104/index.php?tpid=0086&pageno=1
it covers
Supported Models AR-123E, AL1045, AL1216, AL1225, AL1255, AL1530CS, AL1540CS, AL1456
Aug 21, 2009 | Sharp AL-1217 Copier
Often Flashes F5 shortly after power up and then cannot print or copy
It is copy lamp lighting abnormality. It could be a mulfunction with copy lamp, ccd or the wire harness.
May 11, 2009 | Sharp AL-1217 Copier
Sharp AL1216 - error code H4
H4 means the heat rollers aren't functioning. It could be thermistor replacement. You can get fuser parts at precission roller.com if you want to fix it yourself.
Nov 18, 2008 | Office Equipment & Supplies
SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Nov 01, 2008 | Office Equipment & Supplies
My Sharp Digital Laser Copier/Printer AL1216 will not work
This is caused when the fuser doesn't heat up in the allocated time. This can sometimes be fixed with a service reset
[#] key [*] key [C] key [*] key sim 14 start key.
machine should turn off then back on.
If problem is still there it is either the lamp or the thermostat.
Sharp Tech.
Sep 04, 2008 | Office Equipment & Supplies
Asharp AL-1631 won't print anything but a mess.
E7 is a few different things. Are there two more numbers flashing after the E7 appears?
F5 has to do with the copy lamp.
It should be looked at by a technician. It needs to be looked at for the E7 issues.
Jun 13, 2008 | Sharp AL 1631 Copier
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL 1631 Copier Logo
117 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
