Question about Buffalo Tools 4,000 Watt 6.5 Hp Portable Generator #GEN4065
Need a wiring diagram for buffalo tools #GEN4065
Engine low oil & engine shut down circuit
2 Suggested Answers
bozcro
  • 867 Answers
SOURCE: buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
Posted on Aug 17, 2009
Mow for 30-60 min.mower shuts down. Sometimes you can mow all day.start goin up hills mower will shut down,about the second or 3rd trip.what's the problem?
Don't know what kind if engine you have but many have low oil shut down float switches inside the engine..when operating on hills or side if hills too long the oil will flow to the low side and the low oil switch will pick it up as low oil and shut it down..look for a small wire attached to the crankcase it most likely is that low oil switch..the next time this happens try disconnecting it and tape the end if the wire..try starting and run on the hill..it should not shut Down..just remember it is a safety switch to protect the engine from damage from low oil operation.try running the hills where the oil runs to the wire side of the engine..won't trick the low oil alert...Good luck..
Aug 08, 2015 | Garden
On/off switch buffalo bench grinder
The switch is probably generic.. go to a Lighting store and see if they have equivalent
Nov 20, 2013 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Need anew carburator
If you can't get any info from the retailer as to repairers for you machine then check out other gen sets as most run generic carbys on the engines.
Apr 01, 2013 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I need a gas tank for a 4000 watt Buffalo generator.
call buffalo tool parts dept.they have brand new tanks for $36.75 or if you need a petcock they cost $9.95 they also have the gas gauge for $9.60.call 1-800-568-6657
Feb 01, 2011 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
WHO MANUFACTURES THE ENGINE FOR THE BUFFALO TOOLS GENERATOR EX: 4000 W OR 10000 W SIMPLY PUT WHAT KIND OF ENGINE IS ON ANY OF THEM
There have been several factories in china that have made the motors used on buffalo generators, a couple of these are Lifan and J.D. as in Jiangdong.All of these motors are very similar to honda motors.The 6.5,13,and 15 h.p. motors are real brutes and hold up very well.
Jan 01, 2011 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Feb 05, 2010 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I have a 4000 watt Coleman generator that won't
If it has been in storage with gas in it. it is gunked up. Need to remove carburetor and take to someone to clean carb.
Aug 23, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Buffalo tools 4,000 watt generator
Aug 17, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Buffalo Tools 4,000 Watt 6.5 Hp Portable Generator #GEN4065 Logo
95 people viewed this question
Top Buffalo Tools Electrical Supplies Experts
Bill Boyd
Lawrence Oravetz
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
