Question about Magic Chef 9122 Gas Single Oven
Build in Over Gas - Oven does not heat
I have a Magic Chef - built in oven bought in the late 90's - I turned it on and it heated and then stopped. The temp when down and I could smell gas so I turned it off. I was afraid to turn it on again since I smelled the gas. I have the heating element that gets red and turns on the gas on in the broiler section/under the overn. Is there something I can clean or do I need a repairman? I would love to be able to fix myself if possible.
I called a repairman it was the igniter.
Posted on Jan 27, 2009
Oven inconsistant heating up to tempeture how much is an igniter for Magic Chef gas oven
Hello, Thank You for using FixYa. I will be helping you today.You can use ignitor #12400035 Its about $50 but search on google to find the best price.
Thank You and please rate my answer if it was helpful..
Jun 24, 2011 | Magic Chef 9122 Gas Single Oven
I have a magic chef gas stove witch has electric pilots.when i turn on oven it seems the electric pilot lights up but the burner doesn't come on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 06, 2011 | Magic Chef Ovens
Magic Chef: 9122: ingniter works and turns oven on BUT after a few minutes it turns itself off and later it turns itself on again and so on. Igniter problem or thermostat problem?????? Thank you for your...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 11, 2010 | Magic Chef 9122 Gas Single Oven
Oven not heating
If your oven is gas, like it says up top, then your ignitor is bad...
Check out this tip...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 07, 2010 | Magic Chef 9122 Gas Single Oven
Range won't heat up
it is a glow coil , thermocouples are on units with a free standing pilot that you have to light, if you have a range like this you may need a thermocouple if not a free standing pilot you have a electronic gas iginition system that uses a glow coil, you turn on over setting and oven glows orange then iginites if this is what you have you need new glow coil, easy to repalce
Feb 03, 2010 | Magic Chef 9122 Gas Single Oven
How do I troubleshoot my Magic Chef electric built
Hi,look in the control console for the tech sheet or under the top of the unit.A good place to start.Hope this helped.
Nov 17, 2009 | Ovens
I have a magic chef range/oven. For the last few months, it has taken longer and longer for the oven to heat up to temp. Now it won't get more than 90 degrees or so. What is the problem??
Turn off the power to the range. Remove the bake element from inside the oven. Be careful not to let the wires go back into the oven cavity. Take a volt/ohm meter set for ohms or continuity and test the bake element leads. If you get no reading replace the element. If you do get a reading,replace the temperature sensor in the oven.
Oct 08, 2009 | Magic Chef Ovens
My Magic Chef 21MS Natural Gas Oven will not heat up in oven. The top burners are fine.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 25, 2009 | Magic Chef 9122 Gas Single Oven
THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Dec 03, 2008 | Magic Chef 9112 Gas Double Oven
My oven won't work
Replaced ignitor on mine, fixed it.
Nov 18, 2007 | Magic Chef 9122 Gas Single Oven
Magic Chef 9122 Gas Single Oven Logo
182 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
