Question about Maytag Neptune FAV6800AW Top Load Washer
Will not drain - know how to take apart hoses from pump to see bl
This is possibily the worst investment one could make. I should have given my money to the hedge funds guy. I will never by maytag again. I was told that my washer did not drain and was pump related and have sent 150.00 for a pump that continues to break. I was taught by the repair person how to fix this issue and it continues to do the same proplem. My laugndry was smalling for a while and was told that you need to run an empty load of bleach. At what point does this machine save me money?
  • itieflies83 Feb 04, 2009
    Hi other Maytag owners,
    I just tried this test and my pump hums and seems like it wants to run, but still wont drain out the water. I have checked for blockages at length and still don't find any. Does anyone have any ideas past this point? Is there possibly a sensor that I am forgetting? Thanks!
  • dh1200s
    dh1200s May 11, 2010
    Hi Maggie, I understand your frustration. I have been forced into DIY repair mode as an owner of this machine with early failures related dc/UC errors in spin cycle. It’s just not cost affective for me to get repair folks involved and I will continue to DIY the repairs until parts cost trigger a replacement decision. My wife purchased our machine on 7/05.
    "I was taught by the repair person how to fix this issue and it continues to do the same problem." I'm not sure what that means, what did the repair person teach you? With the original problem of not draining the tub did you take the “nd” error in the console display for ““No Drain: The machine has tried to drain””. Let’s try to force the drain pump on in Service mode and see if the drain pump will pump out the water in the tub to get a start point. Do you have the troubleshooting guide for your FAV6800A that was shipped with the machine? It should be located in the Console of your machine. Here are the steps just in case you do not have.
    If you don’t all ready have water in the tub and with no clothes in the wash basket, select Quick Wash to fill the tub. Once the tumblers begin to rotate in wash cycle hit the Off Button to stop the QW cycle. Now we want to check if the drain pump will pump out the tub in service mode.
    We now need to go into service mode;
    1. Enter Service Mode by pressing both the Enviro Plus and Spin Only keys simultaneously until the washer beeps.
    2. Next you need to go into the Board Output Test by pressing the Delicates key, your display should now read “ot”.
    3. Now press the Presoak key this will start the drain pump and it should begin to empty the tub.
    You can press the Off button to stop the test, the test should also time out after 5 minutes. Did the drain pump come on and pump out the tub? I will be waiting on your response.
  • 335 Answers
Hello itieflies83
My two cents: I’m an owner/DIY'er and have not experienced a pump/blockage issue. With the test I speak of the controller board sends 120VAC directly to the pump no other signaling ie. the pressure switch can override the test, you are in Service Mode. If your pump impeller is turning (not jammed) and you have removed the front panel and verified no clogs are restricting input flow to the pump then this test should pump out the tub. I would not suspect a clog on the pump output side but could happen. The noise from my pump running is a little bit louder than a hum. Does the hum you hear from the pump sound familiar as it worked normally in the past? If there is no input blockage to the pump my next step would be to remove the pump, inspect the input to the pump for clog/jam, power up the pump and verify the impeller is turning. If you can’t DIY and you can’t get a local DIY’er to help you then it’s decision time to get a qualified appliance service repair person involved if you are going to keep the machine. Cost would be for the service call and pump. See if they would bring out a pump for the machine on the first service call. They will need your model number and serial number of the machine. Online parts supplier sells the pump for about $40. Maybe other forum members will jump in and offer another resolution path to go down. Good luck to you.
Link for the pump p/n ;
AP4035317.
The parts supplier;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5169371
Posted on Feb 05, 2009
How do i change a drain pump on model # pld2850rdc3 fridgidare dishwasher
http://www.partselect.com/PS1765174-Frigidaire-154580301-Drain-Pump.htm?SourceCode=1&SearchTerm=PLD2850RDC3&ModelNum=PLD2850RDC3
I did this job myself - you need to be comfortable removing a/c power and make sure you make tight hose re-connects. But honestly, I'm surprised this model is still running for you - this design was a total defect with the control boards and touch panel always failing because of condensate/water on the touch panel and in the control board. If those are also failing on your unit - dump the thing and buy a new one before investing money and time in the pump repair.
Jul 31, 2014 | Frigidaire 24 in. PLD2850 Built-in...
I Invested money and never received any roi after 2 years. how can I get my money back
I think there is a condition that you can get back all your invested money back if you want so. The company or the assets where you have invested the various things are suppose to return your invested money back to you but in that case you will not be given any such additional amount as a profit but you can surely have the invested money back.
https://www.structuredsettlement-quotes.com/
Nov 18, 2013 | Computers & Internet
I went to lowes because of a slow drain in kitchen he gave me drain cleaner 100% lye now I have a worst problem it is clogged worst than before have taken all pipes apart under sink the clog is in the...
Rent a snake at equipment rental store just drill type should do it . Since you pull pee trap off already just feed it down pipe until it opens up.
Aug 18, 2013 | Plumbing
I have Sumsung Washing Machine, Silver Nano, WF-B105N, 6kg, I got my drainage pump not working how to get spare part in Doha Qatar, The Error code is 5E, I alrady cleaned the filter.
the drain pump is probably fine on the other end of the filter is a drain pump lean the machine back and take the kick plate off and you will see the drain pump you need to undo three screws holding it to the filter and when you pull it apart your problem will fall out ( normally coins or bobby pins or nails if not take the hoses off as well and check/clear them save you the money and the drama.
Jan 10, 2011 | Washing Machines
Dishwasher not draining water - checked filter that is ok - in the manual is says to check the drain hose is not clogged how do you check the drain hose
The drain hose is connected to your garbage disposal 97% of the time or it feeds str8 into your sink trap. Disconnect it from there. It could be a build of of lime or some other minutia clogging the hose. Worst case scenario is that your pump is bad.
Dec 21, 2009 | Dishwashers
Machine will not drain and registers a Ld display as fault. Is the drain motor burned out?
Hi. Essentially, this will indicate that the drainage assembly is obstructed. There may be a clog at the drain filter, or in the drain hoses. The worst scenario will be a damaged pump motor. I would check the hose Assembly first. Gain access to the pump and hose Assembly. This will require you to disassemble the cabinet, of course. Once exposed, disconnect the pump hoses, and check for foreign materials inside the hoses, and pump housing, as well. If the pump is belt driven, it will not be able to be opened, for internal inspection.
If it is a direct drive pump(on board motor), You will be able to open the housing. This will allow you to inspect the pump impeller for damage. If all is well with the hoses, and drain filter, the pump will be the culprit.
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite flashing codes.
ob means out of balance and ld means lid not closed. so i would guess that you have a washer that is not draining or just needs the clothes moved around.
if you have a plugged pump it will do the same thing. make sure the pump will drain properly and then try it again. if it still goes out then try it with no clothes. that way you know its not hte clothes causing the problem.
recheck the pump and hoses. be sure it will drain the full tub or it wont work right.
Jan 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Math
Mr Tan invested 35,000 and Mrs Tan invested 45,000
The equation to solve this is given by:
mr Tan's money x
Mrs Tan's money x + 10000
x times .05 + (x + 10000) times .05 = 4000
solve for x
Loringh
Nov 06, 2008 | Computers & Internet
Dishwasher model c5420 won't drain. Checked drain hose and air gap, both are clean.
Dear friend,
ngfam at you service! happy to assist!
Sounds like a pump problem !
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | GE Dishwashers
Maytag Neptune FAV6800AW Top Load Washer Logo
623 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
