Question about Directed EIectronics PDDEI4103A DEI 4103A - Automate AM6 - One-Way Remote Start System with Two 4-Button Transmitters
I want to install DEI AM6 remote start w/556U bypass into my 04 4runner.
Are there any diagrams available that will show me which wires from the DEI harness connect to which wires of the 4runner? The truck has factory alarm.
4 Suggested Answers
  • 33 Answers
SOURCE: installing a python 1400xp in a 2004 yukon lx
email sent
Posted on May 06, 2009
  • 1455 Answers
SOURCE: So I have a viper alarm system in my car and
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Posted on Oct 08, 2010
SOURCE: how to install a DEI/BOA 555L GM Passlock 1 &
Hi I am three months that I have problems with my chevrolet trail blazzer LTZ 2002, installing the gas system is drained and the battery with the keys on the framework, since the machine is no longer match and lights a lamp in the dashboard which is the immobilizer! installing this module you can baypassare the original immobilizerHi I am three months that I have problems with my chevrolet trail blazzer LTZ 2002, installing the gas system is drained and the battery with the keys on the framework, since the machine is no longer match and lights a lamp in the dashboard which is the immobilizer! installing this module you can baypassare the original immobilizer
Posted on Oct 23, 2010
Wiring diagram for ce 0890 remote start
On some remote starters, there is print on the back of the remote starter itself. It is hard to see with it being black raised text on a black box. If not there, sorry DEI Viper is pretty protective on their installation manuals.
Nov 28, 2014 | Remote Start System
Toyota Sienna 2004 already installed Valet 561R+556U model, All good ,except one thing (when I start engine with Valet remote , alarm system turn on too ( horns , lights))
only one thing to say here and that is ,---but you will not like it thats for sure --- take the side cutters from tool box and remove it completely ,they go wrong after a whaile as the microprocessors fail and the olny thing to do is cut it out ..
Oct 29, 2011 | Directed Dei Valet 561r Remote...
I have a 94 grand prix with a dei remote start not sure what brand remote says your valet and the fcc id is ezsdei471 and it has 2 grey buttons on it anyway the remote unlocks the doors and the dummy...
It sounds like there's no power going to the starter wire. Try and locate the brain under the dash for the remote start. It should be black and about twice the size of a deck of cards with a few harnesses hanging out of it. Usually it is zip-tied to a wire harness or bracket to keep it secure and from falling down onto your feet. There should be several wires much larger than the others, and you should see fuseholders on the 2 red ones. Usually one of the fuses is used solely for the starter. Check both fuses on these larger wires. Should be 30 amp green ones if I remember right. Also, while you have the brain accessible, write down the model number on the brain itself to help you in the future. Most DEI remotes can be used for almost any DEI/Viper/Your Valet system, so it's really hard to tell what you have just by looking at the remote. If the fuses are fine, you may need to take it to a shop (anyone that sells Viper and such). If you have a chip in your ignition key, it may also be the security bypass module that gets installed with the remote start. You will only have this bypass module if you have the little chip in your ignition key. Hope this helps, good luck.
Chad
Nov 24, 2010 | Viper RCVGC022 Remote Control
The Python 1400 Xp on my 2004 Ford F150 won't start the truck when it is cold. It seems that this is one of the reasons I bought it. Help. I have replaced the battery in the remote already
When you try to remote start it does it crank and not fire? If so, check for a flashing anti-theft light on the cluster. The vest way to bypass the fact antitheft is with a 556U bypass which requires a spare key (I have had some other bypass units fail in extreme cold, not sure why, but I just replaced them w/ a std bypass and it worked flawlessly). If that is not the issue reset the tach learn rate at a higher rpm or even set it to voltage sense with a crank time of .8 sec.
Jan 10, 2010 | DEI Python 1400XP Remote Start/Keyless...
How to bypass security system for remote starter on 2004 dodge ram 2500. the remote starter wont start because of the security system. how do i bypass it?
the easyest way to to this is useing DEI Part# 556U you will nned extra key but i think its easyest.or XKO3 if you dont have extra key.
Nov 09, 2009 | Vehicle Parts & Accessories
GALAXY 5000RS-2W-M Remote Starter
yes, most gm cars/trucks made after 1988, and just about everything after the early nineties requires a bypass. DEI has a very easy to install and use bypass for these vehicles, the 555L is perfect. If you cannot locate this discontinued unit, I have some available. Respond to this solution with your email, thanks
Apr 24, 2009 | 5000RS-2W-1 Remote Starter with...
Installation Problem python
First things first with the 555L installed will the truck start with the key if not then the 555L was not installed correctly if the truck will start with the key then the next step is to use the blue wire coming from the satelite relay box to connect to the 555L I will look for your response.
Mar 22, 2009 | DEI Python 1400XP Remote Start/Keyless...
Trying to install a valet 561r in my 2000 dodge ram 1500 looking for good wiring diagram
http://www.the12volt.com/installbay/file.asp?ID=536
here is a link to the wiring diagram...
Jan 04, 2009 | Directed Dei Valet 561r Remote...
Check Engine Alert
No not that I could find, before you remove the whole this just pull both fuses on the main harness red wire there should be 2 total, also check to see that the white ignition wire is hooked up to the remote start unit as this is a very important wire that needs to be hooked up because it is tyed in with your transmission system
Dec 28, 2008 | DEI Valet Keyless Entry System
Directed EIectronics PDDEI4103A DEI 4103A - Automate AM6 - One-Way Remote Start System with Two 4-Button Transmitters Logo
57 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
