Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Ixus 70 my ixus 700 is saying 'card locked'. it's started doing this with all cards. how do i un-lock?
On your memory card there is a little switch on the side click it the oppisite way you have it and it should unlock the memory card
lock and unlock you want to unlock it
Posted on Nov 08, 2007
    Genius:
  • 2,985 Answers
Card locked and mean the card protection device has been activated. Have you indadvertantly activaded the device? This is usually a button with the 'Key' symbol or can be through the menu on screen. Check your manual If this does not resolve it put you problem to the Tech Support Team at Canon
Posted on Jul 16, 2007
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
Hi! When I put the camera on it says in the display: "locked card". I can print the pictures out but I cant take a new picture or delete the old ones. Whats happened?? C. Its a CANON, digital...
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then insert the card back to the Camera.
Regards
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Mar 17, 2011 | Cameras
Cannon IXUS 40.Saying, Card Locked.How do you unlock it?
In case it uses the SD card, then there is a lock feature in the card. You will need to unlock the card so that it becomes read/write enabled. In lock position, it is read only, so you can read the files from it but cannot create any more files.
Most SD cards have a switch on the edge of one side of the card. Sliding it up or down will unlock or lock the card. When the card is locked, you will not be able to transfer any audio tracks. Nor will you be able to play any copy protected files. We recommend you always keep the card unlocked.
sd%20card%20lock%20slider.jpgNOTE: We have found that on some cards, if the slider is even halfway towards the lock position, the card will be locked. Make sure that the slider is all the way to the UN-locked position.
Nov 24, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Memory Card Locked.... how do I un-lock it?
there should be a little swith on the side of the card. switch to the opposite and then try
Dec 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Memory card locked
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Jul 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Card locked
Dear codger19:
If your camera gives you "card locked" error messages with several cards and you KNOW that the cards are indeed not locked via the sliding lock mechanism, then your camera needs to be sent in for service as it has developed and electrical communications problem within the memory card control function.
I would first however try a hard reset by resetting your camera to the default settings, removing the battery and memory card for two minutes, and then replacing them. Retest the cards for the error message. If it still occurs then call 1-800-828-8080 for your options.
Hope this helps.
Sincerely,
HeavyDLB
May 31, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
MEMORY CARD LOCKED
Unlock it. SD cards have a little slider on the left side (face up) that locks and unlocks it.
May 11, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Memory card locked
Hi everyone,
Here's the solution, I just had the same problem LOL!
1. take the memory card out
2.On the memory card there is a little switch (it will be the little tiny piece on the side of the card thats a different color) slide it up.
That's it!
Bye
Nov 05, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
342 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
