Question about Alpine CDA-9827 CD Player
Alpine CDA-9827 CD Player will not turn on - Alpine CDA-9827 CD Player
TekTrax
SOURCE: Alpine cd redeiver CDA 7837
Just a guess, I’d say who ever installed it didn’t hook up the connector behind it. But lets say they did. In most cases, the radio’s connector bundle will have a fuse. It’s a good idea to check your car’s fusebox first to see if any fuses are blown there. In either case, if you replace a blown fuse with "the right value", and it blows again, have a tech check it out. Note that if you try to get to the rear of the unit, do a little research into how the radio is accessed through the dashboard. Most car radios aren’t quickies to get at and some folks can do damage trying to get at it, but if you methodically take logical steps, you should be able to pull the radio, check the connectors, locate the fuse if it has one. Of course, there may be a wiring incompatibility, meaning, the OEM radio had it’s own specific wiring harness, the Alpine was installed, but someone didn’t get the adapter harness to fit the car. Who knows. Good luck. TekTrax
Posted on Nov 03, 2007
  • 11 Answers
SOURCE: ALPINE-CDA-9854R Radio works but the panel won't light up
the counters on radios with detachable faces go bad forum coronation sum times try a small nail file on them to clean it off
Posted on Dec 15, 2007
SOURCE: Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Posted on Nov 06, 2008
  • 50 Answers
SOURCE: Alpine CDA 9827 using aux mode with ipod shuffle via rca inputs
Unfortunately, the rca outputs are to control an amplifier or crossover. They do make an ipod adapter for that radio, which allows you to control the ipod through the radio. Best Buy or any Alpine dealer should carry something for around $25.
Posted on Jul 06, 2009
SOURCE: alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Posted on Aug 31, 2009
Is the CDA-9827 capable of playing songs from an mp3 player (does it have an input option)?
The Alpine CDA-9827 only has an input connector for an external CD Changer.
You could get an FM Transmitter for your MP3 Player, and play your MP3 Player using your FM Radio in your Stereo.
Here is an excellent MP3 Player FM Transmitter:
http://astore.amazon.com/tps03-20/detail/B000E43GOO
Here is a copy of your Owners Manual.
Jul 24, 2010 | Alpine CDA-9827 CD Player
Jul 05, 2009 | Alpine CDA-9827 CD Player
With my alpine it reads the cds and mp3s and starts playing but i'm not getting any sound. but when i turn the radio on everything is fine.
You have the wrong blue wire powering up the amplifier. Try blue/white . The radio is trying to raise the antenna while you are on the radio and not on the cd
May 09, 2009 | Alpine CDA-9827 CD Player
Can not turn the bass and treble up or down on my alpine CDA-9827
ok i cant see your entire question but to adjust bass and treble on an alpine, you see the knob (the one which u use to turn volume up and down), push it in (itll click) then a screen/textt will come up and say bass or an option once it says bass, turn the knob up or down, then press in again and it will say treble or fader or something else, once again, adjust it and keep pressing in the knob until u reach the volume again. does it work? is this what u wanted?
Apr 11, 2009 | Alpine CDA-9827 CD Player
Alpine CDA-9827 distoration
do you have an amplifier in the car also? if you do then there is probably a problem with the install. also could be a bad ground.
Aug 16, 2008 | Alpine CDA-9827 CD Player
What colour loom goes into a cda-9827? easy question lol black or white???
can you be more specific dont know if your refering to wire loom, light(luminesence) ect post new comment
Nov 29, 2007 | Alpine CDA-9827 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Alpine CDA-9827 CD Player Logo
26 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
