Question about Exercise & Fitness
Audiostrider 800 checksum fail - Exercise & Fitness
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: i have a nordictrack audiostrider 800 that i just
The way to tell if your NordicTrack digital console is bad is to troubleshoot it first. If nothing works, you've got a bad console. The digital console is an important part of exercising. A manual machine will still work even if the console doesn't, but an automated machine needs the console to work so you can adjust things like speed, resistance and incline. You also can't use programs or see your time, distance or estimated calories burned without a working console. The two most common reasons that a console will be dim, display bad results, or won't turn on are bad batteries and a problem with the reed switch.
  1. Replace the Batteries
    • 1 Replace the batteries first, if your machine has batteries. A manual machine such as the NordicTrack MTN 740 will not need batteries, and instead the console is powered by your moving the steps. Check your manual if you are unsure of which batteries to buy. Different machines will require different batteries. The NordicTrack Mini Stepper uses watch batteries, but larger machines will likely need AA or D batteries.
    • 2 Take off the cover to the battery compartment. Remove and discard the old batteries. Replace all of the batteries, not just one if you happen to have one good one. Align them correctly with the "+" and "-" signs as shown on the compartment.
    • 3 Replace the battery cover and attempt to turn on the console.
    Reset the Circuit Breaker
    • 1 Check the circuit breaker. A machine such as the NordicTrack CXT 990 will have a circuit breaker located on the front of the machine. The console will not work if the circuit breaker is tripped.
    • 2 Push the circuit breaker in if it protrudes until it sticks.
    • 3 Try to turn on the console. Check the circuit breaker for your house if this does not fix the console problem.
    Adjust the Reed Switch
    • 1 Inspect the reed switch as the information on the display will not be true if the reed switch is too far from the flywheel on NordicTrack machines such as the MTN 740.
    • 2 Unscrew the two M10 by 82mm button bolts on the right pedal bracket. Unscrew the two M10 nylon locknuts. Pull off the pedal bracket and set aside.
    • 3 Remove the two M4 by 38mm screws. Remove the three M4 by 25mm screws. Slide the right side shield off to expose the flywheel, magnet reed switch.
    • 4 Unscrew the screw that holds the reed switch in place but do not remove it. Slide the reed switch toward the flywheel but leave enough space that the magnet can move freely. Replace the shield and bracket
Posted on Nov 08, 2011
What causes nordicktrack audiostrider 800 to have a squeak?
Hi There ,
Unfortunately there are many areas on an elliptical that can give off noise, firstly check all bolts . Even a slight turn can make all the difference . I repair this brand for the distributor.
Jun 21, 2014 | Exercise & Fitness
What does the "code" 5E mean on the Audiostrider 990 Pro
Go to Nordic track and find out:
http://www.nordictrack.com/
Jan 20, 2013 | Nordic Track NordicTrack AudioStrider 990...
Pedals wount move
OIL IT. IF That doesnt work go to justask.com and they will help.
Oct 30, 2012 | Nordic Track Audiostrider 800 Resistance...
Nordictrack auidostridder 800 elliptical screen dead
Chad Gilbert--
I'm having the same problem with my Audiostrider 800. Fan works, screen and soft buttons do nothing.
I dont mean to sound dumb, but where are these motor brushes? Are they attached to the resistance motor or somewhere else? What exactly am I looking for?
Any help would be greatly appreciated!!
Aug 11, 2012 | Nordic Track Nordictrack Audiostrider 800...
Where to plug in adapter on audio strider 800
you must see you instruc manual. if you do not have download fro
www.nordicktrack.com go to service customer, then to parts&manuals put your model and download. or go to www. fitness.manualsonline.com and download.
God bless you
May 20, 2012 | Nordic Track Nordictrack Audiostrider 800...
Flash test Fail! wChipID = 0x80 - Disimage Info length = 3600000 checksum = 4d8323a7 -starting counting ...................... ................... checksum = 4ad32f1b Test Fail! Press any...
- Disimage Info
length = 3600000
checksum = 4d8323a7
-starting counting
checksum = 4ad32f1b
Test Fail!
Press any key to continue...
Do not work FM,TV,Camera after using wrong rom
Help please with gsmart i120
Merlinwarwar@gmail.com
Feb 16, 2010 | Gigabyte g-Smart Smartphone
Exercise & Fitness Logo
42 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
